TPS Sensor re-set
Old Nov 12, 2020 | 06:19 PM
William's Avatar
William
TPS Sensor re-set
Low pressure light came on due to cold weather. Put in a couple pounds expecting the sensor to reset and go off. Still on, do I need to disconnect the battery and will that screw up my phone? Thanks.
Old Nov 12, 2020 | 08:21 PM
jr105's Avatar
jr105
It should reset after a couple of drive cycles.
Old Nov 13, 2020 | 04:35 PM
GABAR's Avatar
GABAR
Are you sure you don’t have a leak in said tire?
Sensors can go bad so perhaps that’s the issue.
You do not have to disconnect the battery for the TPMS.
Have a tire shop to check for both of the above.
If you have one in your area, Discount Tire will check for free.
I’m not sure how disconnecting the battery can or would screw up your phone but any info related to your phone that you stored in the Infotainment System might be erased so you’ll have to set things up again.
Old Nov 13, 2020 | 05:01 PM
matt167's Avatar
matt167
Turn ignition on, and inflate the tires to correct PSI. It might do it. Although battery in one of them is probably bad
Old Nov 13, 2020 | 06:40 PM
William's Avatar
William
Thanks Guy's. I have a TPMS-19 transmitter that I will try tomorrow and post back. These are new transmitters installed about 6 months ago and the tires are not leaking. I'll check out this transmitter deal and post back.
MrFunkyOne
17
Apr 10, 2017 03:21 PM
MONAVIERONJON
Jun 17, 2013 08:06 PM
octaneforce
Jan 3, 2011 05:38 PM
adamzelazowski
Nov 25, 2008 05:19 AM
Carnivore
2004 - 2008 F150
Nov 1, 2005 10:57 AM
