Sponsored by: Real Truck
Steering
Old Nov 12, 2020 | 05:59 PM
BigDaniel's Avatar
BigDaniel
Steering
My 08 f250 has a steering issue it will drive straight down the road with steering wheel straight and then it will pull hard left and by hard left i mean i have to hold the steering wheel almost 90 degrees to the right any idea what this could be i am putting new ball joints in the front end this weekend would like to get that taken care of too thanks in advance for the help
Old Nov 12, 2020 | 06:36 PM
Djosbun's Avatar
Djosbun
The only way to know what the problem is would be to get the front off the ground and check each component for looseness. If you're replacing ball joints you might as well replace the tie rod ends (I'd replace the center link, as well).
Make sure the brake caliper is releasing on the side it's pulling. A soft or collapsed brake hose could cause the caliper to not release fully.
-- Dave
Old Nov 12, 2020 | 06:50 PM
SnowPlowDriver's Avatar
SnowPlowDriver
Change the axle u joints while you have it apart. A u joint bound up can affect the steering even in 2wd.
Old Nov 15, 2020 | 08:28 AM
BigDaniel's Avatar
BigDaniel
Do you by chance know what all parts i would need to replace the u joints because from what ive seen i have to pull the axle and i cant really figure out what all seals and bearings i need for that
scsi6
Jan 14, 2016 11:14 AM
The1nOnlyFordBoy
May 26, 2012 01:25 PM
smashclash
32
Dec 29, 2010 11:30 AM
89Bulldog
1983 - 2012 Ranger & B-Series
Jun 15, 2010 10:04 AM
