Sponsored by: Real Truck
Door pad question
Old Nov 12, 2020 | 02:47 PM
Big-1's Avatar
Big-1
Door pad question
Anybody know how I can get my door pad entry code? If I search my VIN number, would that help?
Old Nov 12, 2020 | 03:17 PM
SnowPlowDriver's Avatar
SnowPlowDriver
On my 2011 the code was on the wiring loom going into the BCM
Old Nov 12, 2020 | 03:18 PM
Big-1's Avatar
Big-1
Excuse my stupidity, but BCM?
Old Nov 12, 2020 | 03:57 PM
seville009's Avatar
seville009
basically get a flashlight and look up under the dash. Do you by chance have the original owners manual? It would be (or was) in there if you do.
https://www.ford-trucks.com/forums/5...locations.html
Old Nov 12, 2020 | 06:58 PM
Big-1's Avatar
Big-1
When I bought the truck, it did not have an owners manual. Let me see if I can find it.
Thank you,
Old Nov 13, 2020 | 07:25 AM
saratoga2011's Avatar
saratoga2011
You can do it easily with ForScan.
Old Nov 13, 2020 | 12:49 PM
Fatz29708's Avatar
Fatz29708
You'll find a second white insulation wrapped snugly across the computer module. When you push the insulation up to see the flat surface, you see the 5 digit number printed up-side-down in black on a white sticker. This is your keyless entry code.
Old Nov 14, 2020 | 10:26 PM
alxsnmr's Avatar
alxsnmr
If you're flexible enough, open up the knee storage box all the way. Popping it out to hang down (hopefully it's empty otherwise it soon will be. Lay with your back on the seat and head hanging off the front looking through the hole with a bright light source. You'll see white insulation/batting hanging down. Push it up and away to see the control module. Read off the 5digit number. Ignore any letters. That will be the factory code.
Then precede to your nearest doctor or chiropractor because you're going to be sore from the contortions.
Vadis
British Columbia
May 7, 2014 12:04 AM
chaser1602
Jan 19, 2014 09:19 PM
ayden2004
Jan 26, 2010 09:22 AM
ekim55
Mar 28, 2006 08:12 PM
tberry333
May 6, 2004 12:33 AM
