Radiator leak
Old Nov 12, 2020 | 10:13 AM
Muni's Avatar
Muni
Radiator leak
Hey all,
1993 F350 7.5L
So I've got a decent radiator leak. I just wanted to pick yall's brain about quality radiators. How long do the cheapish ones last? Here is a rock Auto link to the available radiators for my make and model:
https://www.rockauto.com/en/catalog/ford,1993,f-350,7.5l+v8,1126741,cooling+system,radiator,2172
Anyone have any suggestions? I don't mind spending more if it's worth it.
Also, is there anything I should do while I'm in there? The hoses seem ok on the outside but they're 27 years old. Is swapping those out a good idea?
Thanks
Old Nov 12, 2020 | 10:33 AM
Mikulh's Avatar
Mikulh
Believe it or not I've had good luck with my AutoZone radiator, and it has a lifetime warranty if it does start leaking.
I would swap out the 27-year-old hoses while I was changing the radiator.
Old Nov 12, 2020 | 06:13 PM
kevinv10's Avatar
kevinv10
Originally Posted by Muni
Hey all,
1993 F350 7.5L
https://www.rockauto.com/en/catalog/...,radiator,2172
Thanks
I would definitely do new hoses. Maybe belts while you are in there.
Old Nov 13, 2020 | 07:55 PM
spurredon's Avatar
spurredon
I just this week got a new radiator from Summit for 129 bucks for my '93 5.0, Really nice unit. The original was 1inch thick while this is a two row core. I had to make a couple holes to hold the fan shroud but overall nice. Free shipping over $99. To me, all the hassle to change a radiator keeps me from buying the cheapest one out there. I always call summit when I order and verify that what I think will work does! This is what I bought and it claims it also fits the 7.5!
https://www.summitracing.com/parts/sum-380534 They do have bigger and more expensive as well.
Old Nov 16, 2020 | 12:54 PM
Summitracing's Avatar
Summitracing
SPONSOR
OP,
We have replacement radiators that we would recommend. These are aluminum cores with plastic tanks. One of them is our Summit brand SUM-380534 that spurredon mentioned. The other one is this Mishimoto MIO-R1451-AT. Both are great options to go with to help keep your 460 cool.
Depending on your budget we also have all-aluminum radiators available. These range from $300 up to $1,000+. Some aren't direct-fit and would require modifications to make them fit. These may not be what you're looking for but just giving you options.
It's a good idea to replace the hoses while replacing the radiator. We carry Dayco and Continental hoses for a 93 F350 with the 460.
__________________
800-230-3030
www.Summitracing.com
rtcapo 61
Sep 8, 2019 01:43 PM
justcruzin125
Jul 6, 2015 09:24 PM
Gwilkrrs
6.4L Power Stroke Diesel
May 15, 2015 08:30 PM
FordLou
1997 - 2003 F150
Jul 6, 2010 05:55 PM
cemenacho
Apr 9, 2006 06:42 PM
