Sensor Questions
Old Nov 11, 2020 | 02:19 PM
Leader's Avatar
Leader
Sensor Questions
97 F250HD 7.3 395+k miles.
Retired work truck been used here on the property last few years.
Hard starting, will run fine then...just shuts off.
No cough no stutter no nothing.
Will not restart.
Let it set a few hours and it starts again.
When CPS is bad, does it still work "sometimes"?
How about the other sensors commonly associated with non start conditions?
In the past, I have been taught electronics are either good or bad, no in between.
Don't see any leaks around HPOP.
Really want to get this truck back in service for snow removal this season.
Old Nov 11, 2020 | 02:42 PM
FinnishStroker's Avatar
FinnishStroker
Possible IPR valve acting up when warms up.
Then works after cooldown.
Yes,most common thing with CPS is that it will start right up again.But good to have a new Motorcraft CPS nearby.
Also if you have to swap IPR,OEM is the way to go.
Old Nov 11, 2020 | 07:38 PM
96 OBS's Avatar
96 OBS
X2 on the ipr. Had that problem leave me on the highway a couple times. Make sure the nut on the back of it is tight. It would be good to rule out the cps as well. Pretty common thing like FinnishStroker stated
Old Nov 11, 2020 | 09:39 PM
oldbird1965's Avatar
oldbird1965
Could be the IPR o'rings, this will cause a no start when hot.
Old Nov 11, 2020 | 10:11 PM
Leader's Avatar
Leader
But does it cause the engine to just shut off when running?
Old Nov 11, 2020 | 11:24 PM
96 OBS's Avatar
96 OBS
Yes because it will stop the oil flow to the injectors
Old Nov 12, 2020 | 07:32 AM
TheFecalFanatic's Avatar
TheFecalFanatic
IPR reseal is under 14 dollars from Riff Raff. Would be worth pulling and resealing before dropping 180 bucks on a brand new IPR. I pulled mine for rebuild and I was surprised it even ran. My O rings were very close to going bad.
https://www.riffraffdiesel.com/ipr-c...e-re-seal-kit/
Old Nov 12, 2020 | 08:51 AM
Leader's Avatar
Leader
Well... that does sound better then $180.
Old Nov 12, 2020 | 09:07 AM
96 OBS's Avatar
96 OBS
Definitely a good place to start
Old Nov 12, 2020 | 07:14 PM
oldbird1965
A shut off is caused by the IPR sticking closed stopping oil flow. This is usually caused by the IPR being wore out and/or dirty.
Mine shut off once on a bridge and I was extremely lucky to have enough momentum to roll off the bridge to clear traffic. To get going again the IPR was the last thing I replaced of course, just didn't want the oil mess. I didn't have my mity vac with me.
dmiasin
26
Dec 2, 2020 10:21 AM
Webasto 9.1KW
Apr 24, 2012 07:26 AM
FrankeeD
May 21, 2010 07:56 AM
cparker2
Apr 17, 2007 12:54 PM
AnchorageAk.PSD
Jul 8, 2005 08:42 AM
