Hi everyone. I recently did a swap where I took a 5.8 351 engine and E40D transmission from a 93 Ford Bronco and put it into a 1995 Bronco that had a 5.0 302 and a E40D transmission in it originally. I also swapped the PCM from the 93 into the 95, and had to change one of the plugs on the transmission to match the 93 trans.
Unless I’m reading this wrong isn’t that the opposite of what you said here:
Yes, that is the opposite. At the time the owner had confused me on the years of each Bronco when we were first starting. I know for certain that the 5.8 is now in the 95, as I did run the vin when I found it earlier. Also, since I didn’t realize that the transmission is not in the vin I don’t have that code written down, but I assume by the picture you sent that as an automatic for Broncos the E40D was the only option anyways? If need be I can go back and look and get the code anyways
You need to put all of the original wiring and components for the 1995 Bronco including the 5L PCM back into the Bronco. You need to swap the solenoid pack from the 1995 E4OD into the donor 1993 E4OD or put the 1995 transmission back in. You made this swap way more complicated that it needed to be.
The Air Charge Temperature (ACT) sensor moved from the lower intake to the air filter box around 1994. You can leave the ACT in the donor lower intake (not connected) or remove it then plug the hole.
Why are you recommending the solenoid pack be changed? I would think swapping wires properly to the right connector would be fine and simpler than swapping the solenoid pack... I know there would be redundant diodes...
Personal preference. Keep the pieces than can cause issues with mixing and matching with the components they were designed to work with. While redundant protection diodes is most likely not going to cause any issues, why add yet another variable into this swap that went off the rails.
Plus...the 1995 solenoid pack connector is a better design than the 1993
Alright so I’ve found the plug I need, and got the info I need other than one last thing because I’ve never purchased a computer before, do I just need to get one that matches the codes on the sticker of the one I took out? Thanks a lot again everyone, learned a lot from the great resource that is this website, helps someone like me out a lot!!
Yeah part of the deal was we get the 95 engine and trans so I was gonna have it gone through but after finding Suspect wiring issues I might just leave it. Not sure what I’m gonna do with the pair yet tho haha
