Need some help with engine swap
Old Apr 28, 2016 | 02:16 PM
mr1's Avatar
mr1
I'm trying to install '95 5.o into truck '92 5.0. Dont think its plug and play, so some help please.
Old Apr 28, 2016 | 02:31 PM
Lead Head's Avatar
Lead Head
Just put the '92 harness onto the '95 engine and it will work just fine. Make sure you use the H.O. firing order though.
Old Apr 28, 2016 | 03:07 PM
rla2005's Avatar
rla2005
Ford moved the Air Charge Temperature(ACT)/Intake Air Temperature (IAT) sensor from the lower intake manifold to the air box around 1994. The OP may need to use the lower intake from the 1992. Otherwise a relatively easy swap.
Old Apr 28, 2016 | 05:33 PM
Conanski's Avatar
Conanski
Yeah rule #1 of engine swaps is.. Don't use any wiring that cones with a donor motor. If you still encounter issues like with the IAT sensor mentioned above then it can be dealt with by swapping parts, sometimes that is easier than others but there is always a solution so just ask.
Old Apr 29, 2016 | 04:32 AM
mr1's Avatar
mr1
Thanks for the quick responce. The help is much appreciated.
Armytruckchuck
Oct 17, 2016 05:22 AM
AltonHargrave
Sep 24, 2015 08:59 PM
strd27
Nov 22, 2008 09:55 AM
minnesota4x4
Jan 26, 2006 12:07 AM
