Sponsored by: Real Truck
Engines stalls
Old Nov 9, 2020 | 05:25 PM
Blount13's Avatar
Blount13
Engines stalls
I have a 200 f250 7.3L with253k. It likes to die randomly at low speeds, going into a gas station drive thru ect. Starts right back up. It has a full force diesel 6 pos chip. Have replaced icp and cam position sensor
Old Nov 9, 2020 | 09:44 PM
Colorado350's Avatar
Colorado350
Welcome to the Forum. What year?
Did you use OEM SENSORS? Fuel pressure gauge? Look on the back of the IPR is the tin nut on and tight?
Old Nov 10, 2020 | 07:54 AM
Blount13's Avatar
Blount13
It's a 2000 Yes used OEM sensors. I'll check that for tightness. And no fuel pressure gauge. I disconnected my chip on the way home didn't have any stalls but it took a few to get to idle when slowing down. Sounding like it couldn't make up its mind
Old Nov 10, 2020 | 11:27 AM
Colorado350
That was the other thing I forgot to mention was definitely disconnect the chip. Rule number one when you’re having problems. A fuel pressure gauge would definitely help in the situation to rule out fuel pressure as a problem.
Old Nov 10, 2020 | 03:07 PM
Blount13's Avatar
Blount13
I'm leaning towards IPR?
Old Nov 10, 2020 | 07:25 PM
Colorado350
‘Is the tin nut on the IPR and tight?
larry1954
International Region
Sep 5, 2019 08:40 PM
ldwzlaw
Dec 6, 2012 05:36 AM
GA_Boy
Jan 28, 2008 05:21 AM
txfordluver
Dec 16, 2003 10:51 PM
JLMARTIN714
Sep 13, 2003 11:21 PM
