International Region Australia
7.3l diesel stall
Old Jan 2, 2019 | 06:42 AM
larry1954's Avatar
larry1954
7.3l diesel stall
My 2003 F250 with 7.3l diesel stalled very unexpectedly a few nights ago driving back from the river towing a boat. I was just slowing down and making a right hand turn and the truck stalled. I could not start it again until I turned the ignition to off and then back to on again and cranked the engine and it restarted. I have not any clue as to why this might have happened. Since the engine had to be fully turned off and then turned on again before it would restart, I am assuming that it may be a sensor that is at fault? From what I have read elsewhere, perhaps the crank position sensor?
Never noticed it to happen previously but thought it might have something to do with the led high beam light bar which I have installed, so I started the truck yesterday and ran it for awhile in the garage with the led high beam on, but it did not stall.
Any ideas? The truck has a Banks 6 pack tuner. Maybe I should drive it a bit more to see if I can see some pattern in the stalling or even if it ever happens again. The only problem is that I do not normally use the truck except when towing a boat, and that is a very inconvenient time for it to stall.
Old Sep 5, 2019 | 08:40 PM
larry1954's Avatar
larry1954
Put a scan tool on it and code came up for cam position sensor. Replaced sensor and have had no more problems.
Cavalier240
Nov 16, 2016 03:21 PM
Mike Carol Jones
6.4L Power Stroke Diesel
Nov 4, 2013 03:31 AM
elders3
Jul 6, 2010 08:07 PM
dogger
Jun 6, 2006 09:19 AM
rdnkvudugd1
Sep 25, 2003 08:29 PM
