Need Help: Instrument Cluster Freaking out
Old Nov 9, 2020 | 01:03 PM
Onestepx's Avatar
Onestepx
4wd Low
Hi Guys I have a 2011 350 with 200,000 miles with a 150 Tune DEF Delete & air filter. Truck was running fine up until recently every once in a while the instrument cluster starts shutting off and then restarting itself other times it will start setting off air bag symbol Check brake system warning light battery light speedometer starts jumping up & down service wrench Turn signals stop working and running lights wont shut off & rear camera stops working etc.I have to disconnect batteries to shut lights off again only when it acts up. When this happens it has no effect on radio or air conditioning or engine performance. Here is the weird part will act up all day then out of nowhere everything will just goes back to normal and work fine for a month or longer but when it happens sporadically will last a couple days or so then go away again.
Old Nov 9, 2020 | 03:11 PM
dirthawg's Avatar
dirthawg
Are there any trouble codes present? Battery light on?
It could be the red wire leading to the alternator. Here is the location to look for corrosion.
There is also a black and grey connector that is attached to the parking brake bracket that has been known to cause the dash to go bonkers with a bunch of warnings. If you use your parking brake a lot have a look at this video.
Old Nov 9, 2020 | 09:04 PM
Onestepx's Avatar
Onestepx
4wd Low
Thanks I will check both of these things out tomorrow just wondering when the dash acts up the running lights wind up staying on & wont shut off so I just been disconnecting the battery overnight would the 2 things you asked to check also have any effect on lights staying on?
Old Nov 10, 2020 | 05:24 AM
dirthawg's Avatar
dirthawg
I don't believe so, you are the first that I have seen post about running lights not turning off.
I'm not 100% positive but I think the body control module controls the light timeouts.
Old Jan 17, 2023 | 09:08 PM
mgadde's Avatar
mgadde
4wd Low
Any update to the fix for this issue? My 2011 is doing about the same thing. Entire dashboard blanks out, fogs turn off and come back on randomly. I have dismounted the harness from the parking brake. Gave it a few tugs this evening while it was acting up and it had no effect on the issue during my drive home.
Noticed this evening that the alternator seemed to be hunting for voltage just before the driveway. Battery cable harness was replaced 2 years ago so I may check that out. No battery light though.
Edit: My issue encompasses the entire dash, AC and radio turn off too
Old Jan 18, 2023 | 08:35 AM
KodiakF250's Avatar
KodiakF250
My first thought is something possibly wrong with the voltage regulator or the plug behind the parking break that mentioned previously. Have seen a voltage regulator cause very odd symptoms including gauges doing weird stuff, the weird symptoms won't make any sense because they aren't related to each other besides getting poorly regulated power Pretty sure most vehicles now have the voltage regulator built into the alternator.
Old Jan 18, 2023 | 11:34 AM
mgadde's Avatar
mgadde
4wd Low
I spent last night looking at forums and I think you are right.
Before I parked the truck, I had an issue with the passenger side speakers cutting out while driving over rough terrain. The alternator went, replaced then parked the truck to drive my other one for a bit. I had a few miles on the new alternator and boom, dash starts to act up like the speakers. I asumed the speakers were related. I'm going to dig into it when I get the chance and test voltage to see if the alternator is the culprit. If not, guess I'm getting the opportunity to perform an old fashioned pinout test of my dash harness...
Old Jan 23, 2023 | 04:29 PM
mgadde's Avatar
mgadde
4wd Low
I am stupid, plain and simple
So broke out the fluke 789...
Place my alligator clips on the battery. Start the truck and check out the alternator while its spinning round doing its thing. Figure why not, start here and work my way down to the concrete. Feel it up, find the control plug, give it a quick wiggle... see nothing change. Figure I'd make sure it's seated while I'm there. A distinguished click sound was noticed. Quickly and shamefully put meter away as I was the one who installed the alternator and didn't seat the connector...
Going to drive the truck again to verify this fixes my problem. SMH
Old Jan 24, 2023 | 04:41 AM
KodiakF250's Avatar
KodiakF250
Any update?
Old Mar 13, 2024 | 09:17 AM
Gary7916's Avatar
Gary7916
1st Gear
Anyone figure this issue out yet?
Having the same issues, warning lights going crazy than cluster goes dead but radio and heater still on, and if u shut off truck it will not restart until dash comes back on. Took it to shop 3 times and they can’t figure it out.
Old Mar 13, 2024 | 05:07 PM
Desert Don's Avatar
Desert Don
Watch The videos in post #2 of this thread. Pay particular attention to the third one. Don’t just wiggle the connector, unplug it and reseat it likle he said he did. If it cures your problem, move the harness to a location that the park brake does not vibrate the connector when you release the brake.
Old Mar 19, 2024 | 10:13 PM
KRSCHWEIZ's Avatar
KRSCHWEIZ
2016 F350 I had this same issue several times. Problem is at the parking brake area, wires not secured into the "connecting Blocks" as ford put it. Use the parking brake and release the dash goes crazy. Happened to me several times when pulling 5er, WTF.. All resolved now but a PIA when the truck would not start after instrument panel goes BONKERS.
Old Apr 28, 2025 | 01:18 PM
Dallas0418's Avatar
Dallas0418
1st Gear
Hey if you found the issue please let me know. Justdoitdtrain@gmail.com
Onestepx
May 10, 2023 05:21 PM
Gasrgoose
2009 - 2014 F150
Jan 7, 2014 07:48 PM
pabear89
Escape & Escape Hybrid
Aug 24, 2011 12:57 PM
mwkobe
Mar 4, 2010 09:03 PM
Norm Carter
1978 - 1996 Big Bronco
Apr 26, 2004 11:00 PM
