Carburation problems??
Old Oct 24, 2003 | 08:02 AM
luckild's Avatar
luckild
Inserting the plunger into the pump bore is trickey, Iwould assume that it is not installed properly. Simply redo, while your in there,follow instructions on float adjust and try again. good luck.
Old Oct 24, 2003 | 08:19 AM
774x4's Avatar
774x4
What are you referring to when you said the plunger into the pump bore?
Old Oct 24, 2003 | 09:15 AM
Ratsmoker's Avatar
Ratsmoker
I think he is referring to the diaphragm. I would just take it apart. You might see something very noticeable.
Old Oct 24, 2003 | 11:23 AM
774x4's Avatar
774x4
Well, I solved my problems, I ordered a edelbrock performer intake and a 600cfm carb for it. I wanted to do it in the future anyway so what better time then now! I hate carburators! To bad I couldn't hook up some fuel injection!
Old Oct 24, 2003 | 01:11 PM
Mike G's Avatar
Mike G
Ohhh, where there is a will, there's a way
Old Oct 27, 2003 | 10:42 AM
774x4's Avatar
774x4
Well I got the 4 barrel on it and it runs excellent! Muuuuuccchhh better than the 2 barrel junk! I got the edelbrock performer intake and a 600cfm electric choke edelbrock carb! It seems to have given it quite a bit of power to. I like it!
Old Nov 2, 2003 | 02:02 AM
Justoldbobo's Avatar
Justoldbobo
What size motor did you have by the way? Did the upgrade break the bank?
Old Nov 3, 2003 | 06:45 AM
774x4's Avatar
774x4
I think it is a 390. I'm still not sure yet but it seems awfully fast to be a 360.
Old Nov 3, 2003 | 07:02 AM
Ratsmoker's Avatar
Ratsmoker
I once thought my unknown FE was a 390 as I couldn't believe anything smaller could be so torquey in its feeble condition. It was a 360. Its a 390 now though.
Old Nov 3, 2003 | 10:34 AM
774x4's Avatar
774x4
Maybe its a 360 then, I'm not sure. That dowel method to find out what the stroke is just doesn't seem like it can possibly work, has anyone actually tried this or is an urban legend that someone made up and now everyone just says to do it?
Old Nov 4, 2003 | 07:22 AM
Ratsmoker's Avatar
Ratsmoker
Yes it works. How could it not? It is very simple and I have done it a few times.
Old Nov 4, 2003 | 08:15 AM
774x4's Avatar
774x4
Is there a thread somewhere that explains how to do it? I did a search and really didn't come up with a good explanation. Thanks for the help.
Old Nov 4, 2003 | 08:48 AM
  #28
Ratsmoker's Avatar
Ratsmoker
Post it as a new question so everybody can see. Lets keep this one about carb problems.
Tparkin99
60
Jul 3, 2016 09:17 AM
Mdc9966
Sep 16, 2015 11:20 AM
jamesB3
21
Apr 1, 2015 06:54 PM
Bayou-66F100
Oct 27, 2014 04:34 PM
Buck762mm
Jun 7, 2014 01:02 PM
