e150 idling problem
Old Nov 12, 2020 | 01:35 AM
willem_at_work's Avatar
willem_at_work
Close to 170.000 if i have to trust the gauges. I will do this check tomorrow, already ordered the parts though.
I am planning on doing this in two days, parts i got are:
1. Timing set of 2 gears and a chain MELLING TIMING SET 3163SB https://www.rockauto.com/en/parts/me...iming+set,5756
2. gasket set for timing cover FEL-TCS 45449 Timing Cover Gasket
for tools i have ratchets etc. and a puller for the harmonic balancer.
This should be enough right?
How hard is this from 1 to 10 on the pain in the butt scale ? I mean, ive done this with other cars, but i can imagine this is extra hard with a Van since everything is difficult to get to
Old Nov 12, 2020 | 07:16 AM
jackietreehorn's Avatar
jackietreehorn
6.5/10 Depends on your tools, skill level and whether you are doing this in a climate controlled garage or in the street. It's relatively easy with the engine removed, but a decent PITA inside a truck, probably even more so in a van. You have to pull the radiator shroud, fan, power steering bracket, water pump, and timing cover plus various hoses etc...
Make sure you line up dot to dot on the timing set and it would be a good idea to set engine to TDC before you tear it down.
Make very sure your timing cover is not cracked and be sure to carefully torque it down to avoid cracking it. Make sure you line up the alignment dowels for the timing cover and use a skim coat of good RTV on both sides of all gaskets involved. (except oil pan "U").
You should add a quality water pump to your parts list as well.
Be careful not to strip the crank bolt threads too.
I wouldn't rule out vacuum leaks and other problems
saltydog463
Jun 27, 2013 01:13 PM
dmikel
Large Truck
Nov 3, 2011 09:55 PM
tored1971
Mar 24, 2008 10:31 AM
ZeroBoyWD
Jan 9, 2008 12:05 PM
Aerocook
Aerostar
Jul 26, 2004 08:29 AM
