Help with error codes
Old Nov 7, 2020 | 02:41 PM
paulwjax's Avatar
paulwjax
The other day ran a couple errands and the truck stalled when I was backing it into the driveway and wouldn't start back up until it was cold.
Pulled the codes and I got the following when it was running again:
41
32
77
25
Any suggestions?
Old Nov 7, 2020 | 05:16 PM
hobohilton's Avatar
hobohilton
https://www.troublecodes.net/ford/
this may help.
Hobo
Old Nov 7, 2020 | 05:25 PM
Franklin2's Avatar
Franklin2
Code 41 is the oxygen sensor. The computer saw the voltage was low for a extended period of time. Vacuum leaks, ignition problems, or a actual bad sensor could be the problem.
Code 32 is the sensor on top of the EGR valve. The valve did not move like it was supposed to. If you have a bunch of vacuum lines disconnected, you will get that code. If the EGR happens to stick, you will get that code. If the sensor on top of the EGR is bad, you will get that code.
Code 77 us usually caused because during the test when it told you to, you did not goose the throttle. You have 10 seconds to goose the throttle after it signals you to do so. If you have a code reader, it should have instructions to tell you when it occurs.
Code 25 is for the knock sensor. It checks this sensor when you goose the throttle, so if you do that part correct this code may go away with the other one.
Old Nov 7, 2020 | 08:40 PM
paulwjax's Avatar
paulwjax
So I was able to go out and test again and did what the directions said and blipped the throttle after it flashed the 10 code.
This time code 77 went away and I was left with
41
32
25
I also pulled out my multimeter and tested the egr sensor and got 5 volts in the plugs with the KOEO. Then measured resistance across the poles on the egr valve and got about 5ohms.
Sounding more like a vaccuum leak somewhere based on what Franklin suggested?
Old Nov 8, 2020 | 07:16 AM
Franklin2's Avatar
Franklin2
Guy in the book says when it tells you to blip the throttle, you need to make sure you get above 2000 rpm. If you want to make double sure about code 25, he says when the test tells you to blip the throttle, instead take a small hammer and peck rapidly on the exhaust manifold. That should make code 25 go away. If not, there is something wrong with the knock sensor or it's wiring or wiring plug. I would not worry about that too much though.
You can try the oxygen sensor and see if that fixes 41. If you are getting hints that the engine is not idling very well, you might want to try to fix that first.
On the EGR valve, see if you can get your fingers underneath and move the valve. If you can, see if it's stuck. If you can move it, put your meter on ohms and then measure the sensor terminals while you are moving the valve and see if it changes smoothly.
Old Nov 8, 2020 | 12:16 PM
paulwjax's Avatar
paulwjax
New o2 sensor fixed code 41, thanks Franklin. 25 is also gone since I hit 3000rpms during the test.
However,
Still have 32. I was able to move the egr valve and watch the resistance move smoothly. Not sure on this one.
Also got a new code - 44.
Old Nov 8, 2020 | 12:44 PM
Franklin2's Avatar
Franklin2
A lot of things can happen with the EGR system, a lot of places for failure. Code 32 means the voltage from the sensor on top of the EGR valve (the EVP sensor) was below .29 volts. You didn't say, but I am going to assume you have a 1986 302 fuel injected engine. The diagram for the EGR is below. The common 5v supply is the orange/white wire. The common ground wire is black/white. The signal wire to the computer for the EVP sensor is the brown/lightgreen wire going to pin 27. With the key on, engine off, take your meter and put the black lead on the black/white wire and the red lead on the brown/lightgreen. See what voltage you get. If it's below .29 volts that is what is causing the code. If the wiring and the connector are good the guy in the book says to replace the EGR valve.
Old Nov 8, 2020 | 01:00 PM
paulwjax's Avatar
paulwjax
Yes it is a 302 efi, sorry I didn't mention that.
When I'm testing this
"With the key on, engine off, take your meter and put the black lead on the black/white wire and the red lead on the brown/lightgreen"
am I backprobing the connection while it's on the egr valve or do I remove the connector and test it?
Old Nov 8, 2020 | 04:20 PM
Franklin2's Avatar
Franklin2
It's best to back probe it if you can.
Old Nov 8, 2020 | 04:46 PM
paulwjax's Avatar
paulwjax
Getting a very consistent .52 volts.
Should the engine be warmed up? I got this voltage reading KOEO and engine cold.
Old Nov 9, 2020 | 07:44 AM
Franklin2's Avatar
Franklin2
Should not matter if the engine is cold for that test. .52 volts is good. Either there is something wrong with that signal wire to the computer and the .52 is not getting back to pin 27, or there is something wrong with the computer. You might want to pull the battery cable off for a minute and then reconnect it. Then drive it normally and then pull the codes again.
Simon6.0F350
Oct 2, 2020 07:51 PM
NinthGenF-SeriesOBS
Mar 24, 2016 04:03 PM
tva13181
Aug 8, 2011 11:50 AM
duncannon6
Bronco II
Oct 30, 2006 01:23 PM
