Lost my 2019 F150 car key fob
Hi all,
I lost my 2019 F150 key fob, and it looks like I need to tow the car to the dealership who wants more than $500 for a new key fob.
Any idea or suggestions what should I do? maybe a cheaper way?
Thanks a lot!
Thanks a lot!
Last edited by nati222; Nov 7, 2020 at 04:20 AM. Reason: lost my key, not my truck
Do you still have your 2nd key FOB? I thought I saw a thread about DIY cloning as long as you had at least one FOB...
On edit: did some searching to find a thread to help, and from what I read, you need both key fobs and then can clone a third. It looks like your only option is to go to a dealership. Follow seventyseven's advice and check other dealerships as I read there can be a wide range of what they charge to do a replacement fob...
The same would be required if you go to a locksmith and that’s contingent if said locksmith has the proper equipment to program new fobs.
With that being said and regardless of where you take your vehicle, at the very minimum, you’re going to be in the $250.00-$600.00 range.
agreed - do your research in your local area, and get a few different quotes from a few sources...
there's some useful info regarding what to do when you loose keys, and there's also a function to help you find a nearby locksmith
Thanks a lot. actually thats exactly what I did. Couldnt find a dealer that would do it less than $450, not including towing.
I had a locksmith come and he cut the key on site for my, then he connected a special machine and it worked fine.
Charged me $420 total.
Thanks for your help!
also - have a read here https://lost-car-keys-replacement.com/ford/
Helped me a lot actually. ended up paying a fair price I believe.
My lesson, make sure you guys have a spare key..
Be wary of the hardware store keys, many of them are "clones", which duplicate an existing key exactly. Two of those cloned keys are NOT the same as "two keys" as the truck sees them as exactly the same key!
