Hey, I have 2020 f-350 that’s getting a lift and I’m plannning I’m running 285-75-18 tires.
my question is, can the dealership adjust the speedometer? I have read that it can be done for stock size tires and this is stock size for the tremor.
can it be done? If so how do I tell them to do it?
thanks for your help
I believe I have see postings regarding folks using FORScan to make changes to the calibration for various tire sizes. You might want to do a search here and the the FORScan site.
Side question on this, do you have to recalibrate the speedometer? I mean, if you don't, other than the speedo and odometer being off, will it mess anything up on the truck?
Tires sized above a certain threshold would throw a code and light on previous models. I don't recall what the size was. Possibly 37's. The miserable search function on this may tell you something, it may not.
Also, I'm told the computer system on the 2020 is a little different and that's likely why our FORScan gurus are still hard at work sorting out and adding mods for the 2020 model year.
Using ForScan give these values a shot. You may get a CEL (P160 code) but shouldn't as it is very close to the stock Tremor size
BCM 726-15-01 xxxx xxxx 0Axx
BCM 726-15-02 80xx xxxx xxxx
