Speedometer is 5mph off.
Old Sep 2, 2004 | 12:48 PM
flat4vw's Avatar
flat4vw
Hey guys,
The speedomoter on my truck reads 5mph faster than the actual speed. I'm assuming that this is because the previous owner put larger than stock tires on it (but i havent even had time to look at what size they are). Anyways, i was wondering if this means that my odometer is also wrong? My truck is a 1995, 300-6, 5 speed, 2WD and just FYI, it has a digital odometer/trip meter
thanks,
--john
Old Sep 2, 2004 | 07:11 PM
andym's Avatar
andym
Sounds like you have 31" tires on it. That will put it off by about 5mph. And yes, your odometer is off by about 5% too for as long as you had the bigger tires on it.
Old Sep 2, 2004 | 07:29 PM
flat4vw's Avatar
flat4vw
pretty sure they're not 31's, its a 2WD. I'll check when i get home this weekend. they look smaller than stock, but again, i havent looked up the stock size for that year/bodystyle yet
thanks!
Old Sep 2, 2004 | 08:19 PM
92lightning's Avatar
92lightning
If your tires are smaller than stock ,yes your odemeter would be the same % off as the speedometer. I think that is why the guys with the big tires think they are getting bad milege.
Old Sep 2, 2004 | 11:15 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Larger than stock size tires cause the speedometer to read s-l-o-w-e-r than actual vehicle speed. Smaller than stock size tires have the opposite effect.
andym's Avatar
andym
The stock size will be printed on the driver's side door post.
Why would anyone put -smaller- tires on a truck?
Old Sep 3, 2004 | 08:41 AM
flat4vw's Avatar
flat4vw
i have no idea - they sure do look pretty though!
Old Sep 3, 2004 | 12:01 PM
buddy555's Avatar
buddy555
You can reprogram the speedometer on your truck. There is an article on how to do it in the 'tech articles' section.
By changing tire sizes the speedometer is out by a percentage of the reading on the speedometer, not a fixed value like 5 mph.
Example: When you increase the tire size from 30in to 33in you will be going about 10% faster than the speedometer says you are. At 60 mph on the speedometer you will be going around 66 mph, but at 10 mph on the speedometer you will only be going around 11 mph.
Old Sep 3, 2004 | 03:38 PM
ditto's Avatar
ditto
smaller then normal tires. if it's moving back and forth (mph) then it might be a lose cable too.
Old Sep 3, 2004 | 09:40 PM
broncobasher's Avatar
broncobasher
Why smaller tires? That will give you better low end torque. Quicker off the line just as putting a larger tire hurts your acceleration.
