Thinking about picking a 2014 6.7 from a private seller. I going to have it looked over by the Ford stealership. Other asking for them to inspect the vehicle. Are there any additional test I should have the run to check the condition of the engine. Are there any areas that I should pay attention to?
Look under the truck to see if the emissions were deleted. If there is a straight pipe under there you have a deleted truck and need to make sure the seller has the tuner.
I have a 14. My third super duty. Drove it off the lot in Feb 2014. 88,000 miles. Has not been in the shop for anything but a few routine maintenance items. Best of the three and that includes a 2001 7.3:
I went and checked out the truck. The owner had several injectors replaced in June. I saw where they had run the IDS. The truck is stock, nothing has been modified. Looked up under the truck, clean as a whistle.
If the priced is right than i would not have a problem buying this truck. However the 11.14 had turbo issues so be careful. Not sure if Ford has a way to check them.
