Driving without fuel cap
Old Nov 3, 2020 | 06:47 PM
Crotchety Ford truck only's Avatar
Originally Posted by PentaPop
Got a latex glove or maybe a condom? Slip it over the fuel nozzle until you get a new cap!
That's a great idea, something like a balloon, easily available anywhere, tight seal with out any fuss, no adhesive residue.
Wonder if the fumes would hurt it.
If you used a rubber, you'd have to get one unlubricated. I wonder if it should be ribbed or not.
Old Nov 4, 2020 | 12:50 AM
OffBalance's Avatar
OffBalance
Originally Posted by BillyE
Diesel has a regular cap.
Gas has a regular cap.
Old Nov 4, 2020 | 04:50 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Originally Posted by GABAR
So the SD’s don’t use the Capless system like the F150 and other Ford vehicles?
Are diesel equipped vehicles required to use a regular fuel cap?
Just wondering because I don’t know.
No. Not regulated. My 2016 Cummins was capless.
Capless is a stupid design. It just invites dust, dirt, water (snow) to enter the fuel tank. A very bad combo with how sensitive a diesel's fuel system is. There is a huge aftermarket segment for caps for the Ram trucks to fix the capless issue...I had a set on mine (diesel and DEF fill ports)
Old Nov 4, 2020 | 04:02 PM
GABAR's Avatar
GABAR
I learned something new today.
Thanks guys.
Old Nov 4, 2020 | 04:43 PM
Screamingbear's Avatar
Screamingbear
My fix
I would use a small Ziploc bag and a heavy rubber band or a zip-tie until i got a permanent fix.
Old Nov 4, 2020 | 05:28 PM
Kellem's Avatar
Kellem
Originally Posted by Faceplant409
Some ******* dropped his fuel cap and another truck ran it over....
I have a 1 hour commute with no fuel cap.
Prolly throw a code, but what else?
Thanks!
Originally Posted by Rich53
If it is a gas engine truck it may throw a code as it monitors fuel system integrity for evaporative emissions, if it is a diesel it shouldn't throw any codes, the diesel tank is not a closed system, no evap emissions requirements.
Sounds perfectly reasonable.
Old Nov 5, 2020 | 02:20 PM
Chimpo's Avatar
Chimpo
Either way, just as long as it hasn't been used before.
Old Nov 5, 2020 | 03:37 PM
Agreed............................................ .....
Old Nov 7, 2020 | 08:20 AM
markp59's Avatar
markp59
Cover it but not with anything that will fall in the OBD monitor test will run only if the tank is mid range full. Too empty or too full and it wont run. The test is what turns on or off the check engine light.
No biggie should clear once u get new cap.
deejaynetmix
Jun 28, 2022 10:26 PM
Mr J 125
Jul 29, 2017 08:10 AM
green 69
Mar 13, 2012 07:51 AM
Rust is too a color
35
Mar 13, 2012 04:57 AM
NitrogenTSRH
Oct 17, 2011 04:31 AM
