vent window latch question
Old Nov 2, 2020 | 10:07 AM
blue351's Avatar
blue351
on a 79 f150 reg cab. are the vent window latches supposed to lock in place when closed. and then you push the chrome pin in to open the latch ? am i wrong about that ?
i have a set off of a 79 that lock and on a 78 E150 that lock when closed. according to lmc you have to buy the additional lock assembly to keep someone from opening the latch.
page 47 in their catalog
thanks
hey Bill - if you read this do any of your diagrams show a " pivot washer" in behind the latch ? thanks
Old Nov 2, 2020 | 12:02 PM
CelticOne's Avatar
CelticOne
Regular User
You are correct. The later year (78/79?) had the locking pin. Earlier ones did not.
Old Nov 2, 2020 | 01:16 PM
jdt10768's Avatar
jdt10768
That’s correct, when you close the latch, the pin is supposed to pop out and lock it in place. I have found that the spring is too weak or that there is too much friction on that pin - so it’s hit or miss. This is on my ‘79 f100
Old Nov 2, 2020 | 01:18 PM
jdt10768's Avatar
jdt10768
... yes, there is a wavy washer that goes between the stud on the vent window and the latch assy
Almostconverted666
Jun 24, 2020 05:46 PM
Firewiz
Oct 18, 2010 09:03 AM
dep295
Nov 2, 2008 06:13 PM
justintino233
Dec 1, 2007 10:29 AM
karljay
Jan 24, 2001 07:38 AM
