More e4od problems
Old Nov 1, 2020 | 12:00 PM
Aidanparm38's Avatar
Aidanparm38
More e4od problems
I got a e4od for a 7.3 rebuilt and we put it in and filled it up with atf and it’s been making weird noises and been slipping a lot. It feels like it’s not got enough atf in it and actually it’s almost got too much. What could be the issue? The overdrive off light has been flashing too so please help
Old Nov 1, 2020 | 04:49 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The flashing OD light means that codes are stored that will tell you where the problem is. You need to read the codes to fix this.
Old Nov 1, 2020 | 05:04 PM
Aidanparm38
What kind of equipment do I need to read it?
Old Nov 1, 2020 | 05:33 PM
Mark Kovalsky
That depends on what truck you have.
Old Nov 1, 2020 | 06:22 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
you need either a Test Light, Analog Voltmeter, or an Innova 3145 Ford Code reader....
https://www.troublecodes.net/ford/ this site will get ya going in the right direction.
Old Nov 2, 2020 | 08:14 AM
Aidanparm38
I probably sound dumb for asking this but what does all these abbreviations stand for? Like koeo, ocil, Tmil, osc
Old Nov 2, 2020 | 08:38 AM
Mark Kovalsky
KOEO = Key on engine off - this is one of the self test modes
TCIL = Transmission Control Indicator Light (the overdrive off light)
MIL = Malfunction indicator lamp (the check engine light)
OSC = Output State Control
Old Nov 3, 2020 | 07:30 AM
Aidanparm38
The slipping heart is starting to make me think it’s the torque converter is bad. And the codes might be trying to tell me the transmission is slipping. I still haven’t checked the codes yet because I don’t have a obd1 scanner but I’m starting to think the tc is the problem
Old Nov 3, 2020 | 07:37 AM
Mark Kovalsky
Did you check the level with the trans warmed up, in park, and the engine idling?
If you want to randomly replace parts without doing any diagnostics, go for it. It will be fun watching you spend $$$$ without fixing the problem. Without the codes all you can do is guess.
You don't need a scanner to read these codes. Got a paper clip? www.troublecodes.net/ford
Old Nov 3, 2020 | 08:25 AM
Aidanparm38
I wasn’t planning on just buying a new tc without actually questioning the problem. And yes I did check it when it was level and warm and everything and it shows the right amount of atf
Old Nov 3, 2020 | 09:13 AM
Aidanparm38
Also real quick question. What is the best atf to use in a e4od?
Old Nov 3, 2020 | 10:19 AM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
Mercon V is what you should use
Old Nov 3, 2020 | 10:58 AM
Aidanparm38
Well of course I know to use mercon v but what do you think is the best brand of atf to use?
Old Nov 3, 2020 | 12:04 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
Mobil 1 Synthetic ATF would be my choice.
Old Nov 3, 2020 | 05:46 PM
Mark Kovalsky
I concur with this.
