6.9 Glow plug issue.
Old Nov 1, 2020 | 08:24 AM
ragboat's Avatar
ragboat
1987 F250 with the 6.9 Diesel. It seems like my glow controller is not working. The 'Wait" light only flashes for a moment and there is only a momentary voltage drop. I'm used to seeing about 10-15 seconds of light and voltage drop. Troubleshooting it has me thinking that the latching relay has failed. That can't be purchased separately. I am considering wiring the system for manual control. The Ford manual cautions against that because they use 6 volt plugs and cycle them for fast heating. Has anyone wired for manual control? I'm the only driver so I can limit the heating time to the 10 of 15 seconds I'm used to. I would use the existing power relay but wire it to a push button switch. Any ideas or cautions?
Old Nov 1, 2020 | 08:53 AM
Thejackalope's Avatar
Thejackalope
You should probably post this in the diesel section.
Old Nov 1, 2020 | 12:03 PM
ragboat's Avatar
ragboat
Done. Thanks.
Hantke
Mar 4, 2020 09:05 AM
David Downey
Dec 10, 2019 04:08 AM
f100beatertruck
Apr 11, 2016 07:08 AM
gfemling
21
Jun 5, 2009 11:33 PM
DaveSmith
Electrical Systems/Wiring
Nov 2, 2008 04:19 PM
