Deck block?
Old Oct 30, 2020 | 10:18 AM
cbrown9064's Avatar
cbrown9064
Deck block?
Got a call from the machine shop yesterday and they said the block had "fire rings" in it and needed to be milled. I said "whoa...".
I have never heard of this before. I know what is most commonly known as "fire rings" are a stainless ring installed to help seal off the combustion chamber. But the Customer Service guy (not machinist) said the block had "fire rings" as a defect. I am tried to get clarification and he just repeated the term. I am thinking the block has some kind of pitting/corrosion around the top edges of the cylinders, even after boring. He also did not say how much they wanted to mill the block.
Is this a "thing" and how would you all recommend I proceed? This is a 1994 7.5 that I may doing a stock rebuild on (save for a Comp Cam EFI cam) for my 1967 F-250 4x4.
Thanks!
Chris
Old Oct 30, 2020 | 01:27 PM
cbrown9064's Avatar
cbrown9064
Went to see the block, still had it in the boring machine.
What it was is the head gasket fire ring left a mark on the block. Could not feel it, but it was evident. Decided to mill the deck just to be safe, as we are in to it this far...
Old Nov 2, 2020 | 07:48 AM
headloct's Avatar
headloct
The "fire ring" is not a problem unless the head gasket was leaking and eroded the edge of the bore. How much did they take off?
Old Nov 2, 2020 | 09:57 AM
mark a.'s Avatar
mark a.
If your going to mill the block anyways then I would find deck height and see how much needs to be milled to get to zero deck.
Old Nov 2, 2020 | 09:33 PM
cbrown9064's Avatar
cbrown9064
They will just clean it up, minimal milling.
Yes, I could zero deck it, but this is basically at stock rebuild. Going to stay EEC-IV in my 1967 F-250 4wheel...
Old Nov 6, 2020 | 05:20 PM
cbrown9064's Avatar
cbrown9064
Got block back, the took 0.008" off the deck. Needed it, but minimal! .030 over on the bore.
Time to start assembling!
countryF150
Oct 10, 2006 12:03 PM
Steve's Beast
Aug 4, 2005 11:58 AM
thuggishruggish3000
Mar 21, 2004 07:05 PM
chrowen
May 13, 2003 07:48 PM
rusty9
Mar 30, 2002 11:51 PM
