Sponsored by: Real Truck
6.8L Help Needed !!!
Old Oct 30, 2020 | 07:21 AM
RAD D's Avatar
RAD D
Question 6.8L Help Needed !!!
I have a 2003 F20 Lariat 4x4 with a 6.8L V10 in it and it is acting up. I am getting code PO304. I have changed the number 4 coil pack(twice just to make sure I didn't get a defective one) and the number 10 coil pack just in case it was the fourth coil in the firing order and have replaced all of the injectors and the code is back. On a cold engine I sprayed it down with starting fluid to make sure I had no intake leaks. After I clear the code it will run for 60-110 miles before the code comes back. I am at a loss and everything I now do is chasing my tail. It's not like the code comes back immediately otherwise it would be easier to find the real issue. Fuel pressure is up and it just seems like a constant random (I know but it was the best way to describe it) misfire on cylinder four. Can anyone help or give me an idea as to where to look next?
Old Oct 30, 2020 | 12:52 PM
RAD D's Avatar
RAD D
Thanks for the input replaced the plug too and no did not do compression test but no other code
RAD D
Oct 30, 2020 05:14 PM
pkenn7
Modular V10 (6.8l)
Jan 6, 2010 07:29 PM
greenterror
Jan 21, 2008 02:01 PM
DNJSDAD
Modular V8 (4.6L, 5.4L)
Jan 1, 2006 11:49 PM
yuenglag
1997 - 2003 F150
Oct 18, 2005 10:23 AM
