Aftermarket vct
Old Oct 29, 2020 | 06:00 AM
perryau1996's Avatar
perryau1996
Aftermarket vct
I’m getting a code 0012 and 0010 on my 06 expedition. I replaced driver side several years ago and now it’s time for passenger side. Amazon has some that are relatively cheap. I didn’t use a cheap one last time but I’m curious to know if anyone has used aftermarket and had success. I also have a shudder in over drive between 45-55 light throttle. I’ve put lube gard shudder fix in but it’s still there. All plugs and coils were changed 5 years ago as well. Thanks
Old Oct 30, 2020 | 05:41 AM
JWA's Avatar
JWA
Strictly my opinion here so take that for what its worth.
The only way I'd use an aftermarket internal engine part is IF the hassle of changing it again should it fail is offset by the upfront savings. Add in the inconvenience of it being necessary at the most inopportune time and you have my equation for comparison.
The fact your Bank 2 VCT is still working that would be enough to make my decision---YMMV.
Old Nov 4, 2020 | 12:33 PM
Beechkid's Avatar
Beechkid
This says it all...IMHO.....................
Old Nov 4, 2020 | 12:52 PM
ford390gashog's Avatar
ford390gashog
Absolutely 💯 not! Do not use any aftermarket components in this engine. The only part that can be aftermarket and has been tested as successful is the HV oil pump by Melling.
Old Nov 5, 2020 | 04:44 AM
JWA's Avatar
JWA
Yep, yep and double yep!
wvabeer
Nov 22, 2017 06:04 PM
fordbuyer
Mar 26, 2016 10:59 AM
Chuddleston
Mar 29, 2013 08:52 PM
mnwildfan2k
Apr 21, 2012 08:54 PM
99ExpyProblems
Apr 30, 2010 09:48 AM
