E4od flush vs change
Old Oct 28, 2020 | 06:40 PM
JJF20's Avatar
JJF20
Originally Posted by ZombieF150
.... Every machine is a smoke machine if you operate it wrong enough.
Now that gave me a good laugh!...
Old Oct 28, 2020 | 07:12 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by 4.9brick
Hi,
I believe I am experiencing some torque converter shuddering between 3rd and 4th (od).I have read the cause of this is old transmission fluid. Fix obviously would be new fluid. I was wondering what peoples opinions are on getting the trans flushed vs just changing the fluid. The truck has 93,000 miles and I am uncertain if the fluid has ever been changed. Pretty sure it hasn't. The fluid is a tan color similar to used motor oil and doesn't smell burnt. Would it be safe to get the trans flushed or would that be risky with a 30 year old trans with an unknown service history?
If the trans isn't damaged new fluid can only help it. If it has terminal damage it's going to fail whether or not you change the fluid. It doesn't sound like your trans is damaged.
Originally Posted by Muni
Transmission "flush" is a scam that auto shops use to make more money. Pro mechanics will save the old fluid when they're repairing an old transmission and put it back in.
A pro that knows what he is doing never reuses old fluid. A mechanic that should have a different job would reuse old fluid.
Originally Posted by ford390gashog
Well a heated flush is best, however if you do it yourself you can drain the pan and the torque converter and get 90% of it out. Just use Mercon V when you do the service. As for saving the used fluid above, I know of no shop that does that. It all goes in the waste oil bin.
A heated flush machine isn't needed for this transmission. A non-heated flush machine will work just fine on this transmission.
I do recommend MERCON V fluid.
Originally Posted by 00t444e
Drain and refill don't flush it.
That's because there is an internet myth that flushing a transmission damages it. That isn't true. But you're welcome to believe whatever you like.
Originally Posted by jas88
If you will drain the pan and also the TC, you will get about 12 of the 14-15 qts. out of it. That is plenty good. Do that every 25K miles and that thing will last forever. Put a drain plug in your pan and you won't need to pull it next time.
I disagree about Mercon V, tho. Your truck does not need it and it costs quite a bit more. Just get the stuff at Walmart that is labeled "ATF". It is Mercon III compatible and that is what your truck takes.
I disagree with your disagreement. MERCON V is a superior fluid. It was originally developed to eliminate shudder. It seems like a good choice for a trans that has developed shudder.
A dealership where I worked had a flush machine. You connected to a cooler line and while the transmission pumped out the old fluid the machine pumped in new fluid to keep the trans full. That way it would completely flush the old fluid from the lines and cooler.
Thanks for the info, did you have have any instances in your dealer ship where the flush machine caused damage to a transmission? The main thing I would be concerned about would be washing gunk out of the pan and into the main body of the transmission. I assume that would not be an issue though because you would pull the pan and change the filter first.
A flush machine that is used properly cannot damage a transmission. If it is done wrong, just like if a fluid change is done wrong there can be damage.
The filter doesn't need to be changed. It doesn't need to be changed until the trans is rebuilt. The flush machine doesn't churn up gunk any more than driving the truck churns up the gunk.
That was also after most trasmissions that called for Mercon were out of their warranty period.
Is there a point to that comment?
I am aware of that, but that's just so that the dealerships don't have to keep so many types of fluid on hand.
No, it's because MERCON V is a superior fluid. It was reformulated in 2006 to be compatible with the older transmissions. I wish Ford would have given the reformulated fluid a new name. It would have made all of this simpler.
Originally Posted by Blurry94
Agreed. You can spin your converter around to see if it has a drain plug.
It probably does have one.
Here is a DIY way to change all of the trans fluid: https://www.ford-trucks.com/articles...-transmission/
Old Oct 28, 2020 | 10:53 PM
4.9brick's Avatar
4.9brick
Mark, thanks a ton for the info and for debunking the myths. I will be getting my transmission flushed with a new filter and fluid as soon as possible.
Old Oct 28, 2020 | 11:05 PM
Muni's Avatar
Muni
It's not an internet myth that transmission flushes damage transmissions. Transmission flushes are unnecessary. Draining and changing the fluid at regular intervals is the best way to maintain a transmission.
There are plenty of mechanics who reuse old transmission fluid on an old transmissions on it's way out.
I've had three subarus all go above 200k before I sold them on the original transmission. They shifted great. Never flushed the transmission fluid. Only drained and changed at regular intervals.
I'm sorry this guy has been convinced he needs to spend extra money on a pointless maintenance technique.
Old Oct 29, 2020 | 01:29 AM
JJF20's Avatar
JJF20
Thank you for responding Mark. Appreciate it.
Old Oct 29, 2020 | 03:01 AM
My4Fordtrucks's Avatar
My4Fordtrucks
I was tech for 10 years and no one ever reused the old fluid. How would you even collect and filter it? That’s some shady stuff there. I wouldn’t let them work on anything of mine.
No. it is also a word of mouth myth. I rebuilt transmissions while at the Mopar dealership. Old hard seals and/ or burnt clutches are not going to helped or hurt by replacing the fluid. If the trans is dying it isn’t going to matter.
When Chrysler was still using ATF +3 the recommended service interval (drop the pan and replace the filter) was every 15K miles. If you serviced the trans according to Subaru’s interval then I agree there is no reason for a complete fluid change however that is not what was asked. The OP has no idea when it was changed and would like to replace all the fluid at one time. You can change the majority of the fluid in your driveway without paying a shop for a machine flush.
Mark was a Ford transmission engineer. Interesting that you don’t believe him.
Old Oct 29, 2020 | 03:12 PM
Muni's Avatar
Muni
Yeah so I'm new to the website and I don't know who is who. I'm not a professional mechanic but I am an HVAC and refrigeration service tech so I have mechanical understanding.
I'm not saying I have to be right about the flush I'm just going based of my personal experience and what I've heard from trusted mechanics. I don't know of any shops that would ever save and reuse fluid either. I've got a family member who has been a private mechanic for 30 years that knows their stuff. I go by them and my own personal experience. Even people like scotty kilmer says trans flushes are unnecessary. I'm not saying that guy is right about everything, but he seems to be genuinely trying to provide people honest information.
Anyways, not trying to make any kind of an argument. This has just been my experience. Could be wrong.
Old Oct 29, 2020 | 03:42 PM
ford390gashog's Avatar
ford390gashog
Scott Kilmer is a joke, I would rather take vehicle advice from my mail man......
The only thing he did that I didn't is make 10million off YouTube in 5 years. I will give him props for that!!!
Old Mar 28, 2021 | 06:05 PM
4.9brick's Avatar
4.9brick
I figured I would update this thread for anyone who might discover it in the future. I had the transmission flushed and filter changed in the beginning of November and all shuddering has stopped completely. It shifts smoothly into and out of 4th. If you are experiencing similar symptoms I would recommend changing the transmission fluid.
Old Mar 28, 2021 | 08:00 PM
My4Fordtrucks
Good deal. Sounds like the additives in the new fluid helped.
joewaldner
Jul 22, 2010 10:05 PM
351Inside
Jun 1, 2008 11:47 AM
rpatrick
13
Mar 18, 2007 10:16 PM
bill99psd
15
Feb 23, 2007 09:35 AM
