Sponsored by: Real Truck
Engine Swap???
Old Oct 26, 2020 | 01:18 PM
elcid59's Avatar
elcid59
Engine Swap???
2003 F-250 7.3 diesel. Question, I never haul any loads and my truck is a daily driver. Deisel is more expensive, more expensive to repair. Thinking about an engine swap to a gasser. Does this make sense to do? Too expensive? Better to sell and get another truck? My truck is in great shape, interior is great. Any help appreciated
Old Oct 26, 2020 | 01:27 PM
'65Ford's Avatar
'65Ford
Is your current drivetrain well known and well maintained? And would you be switching to an unknown used gas drivetrain? That would be a big influence for me.
Old Oct 26, 2020 | 01:35 PM
elcid59's Avatar
elcid59
Yes very well maintained
Old Oct 26, 2020 | 02:52 PM
'65Ford's Avatar
'65Ford
If it were me, I'd leave it be....
You're talking swapping wire hardness, motor mounts, ECM (or PCM or whatever they're called), etc and a well cared drivetrain for an unknown drivetrain or pricey drivetrain if correctly rebuilt.
Old Oct 26, 2020 | 04:15 PM
Dan V's Avatar
Dan V
He's going to be swapping ALL the wiring under the hood, the dash wiring and dash itself. So he needs to find a donor vehicle to source it from.
Old Oct 26, 2020 | 04:26 PM
EastB0undAndDown's Avatar
EastB0undAndDown
Sell it and buy a gas truck.
Old Oct 26, 2020 | 04:42 PM
85e150's Avatar
85e150
What he said.....
Old Oct 26, 2020 | 05:08 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That's a very expensive swap. And the truck will lose value. You will be way ahead financially by just keeping the truck.
Old Oct 26, 2020 | 05:50 PM
irydasteelhorse's Avatar
irydasteelhorse
or sell, and find a nice gasser to replace it
Old Oct 26, 2020 | 06:21 PM
farmerfromkansas's Avatar
farmerfromkansas
I am told that the operating expense for a diesel vs a gas truck are about the same. Diesel is higher, but more mpg. Gas is cheaper, less mpg. So switching engines into your current truck will save you nothing on operating costs.
Old Oct 26, 2020 | 06:24 PM
kurthb's Avatar
kurthb
Originally Posted by 85e150
What he said.....
What they both said
Old Oct 27, 2020 | 06:52 AM
redford's Avatar
redford
FTE Leadership Emeritus
Moderator action: 3 duplicate questions merged into 1 thread.
Old Oct 27, 2020 | 08:28 AM
99powerstrokedF250's Avatar
99powerstrokedF250
This. Your diesel, if well cared for, isn't that costly to repair unless something MAJOR happens - which it won't if you're taking good care of it and addressing issues before they become serious. I had a 7.3 and never had any expensive repairs - just lengthy ones when I discovered I needed to replace the external o-rings on my injectors (that took most of a weekend since I didn't have everything I needed right away). I also had 2 6.0 diesels that never had any costly repairs I didn't cause. A gasser in these years is going to get crap mileage, and frankly if you want to use it as a SuperDuty you pretty much have to get a V10.
If you're going to go for a gasser, do yourself a favor and look into something newer with the 6.2. A vast improvement over the 5.4 in these trucks (not that it was a bad motor, but it wasn't well-matched to these bricks). You'll also be getting more gears in your trans, which helps offset the mileage difference somewhat.
Old Oct 28, 2020 | 06:55 AM
phillips91's Avatar
phillips91
I would keep the 7.3 if it’s well maintained and the truck is in good shape. It’s reliable, gets good mpg’s and is easy to maintain.
Old Oct 28, 2020 | 09:04 PM
Evan_P's Avatar
Evan_P
If you like the truck, keep it and buy a cheap commuter car for daily use that gets good fuel mileage.
DSLPOWR
Apr 3, 2019 09:34 PM
qazwsx213
Dec 7, 2011 02:07 PM
copracr
Oct 12, 2011 07:51 PM
