I'd like to remove the AIH relay to make some room under the hood. What do I do with the wires? Tape them up or can they placed onto the GPR relay? My main concern is the thicker gauge constant hot wire on the relay. Thanks
Put the fat wire on the GPR or cut it out of the harness. The small wires carry a ground signal IIRC and can be taped up. (There will be a soft code from this)
i imagine you can lay them back along the harness and tape them out of the way., I did this ( the link i show) Never thought about taking it out
lol SSJ is here , he knows way more then i ever will!
This is an awfully thick power wire to just tape up. If it were to short out then bad things will happen. I would consider placing it on the hot pin of the GPR as SSJ mentioned.
