Steering wheel swap
Old Oct 24, 2020 | 08:54 PM
Gary Simons's Avatar
Gary Simons
Steering wheel swap
My 97 F350 has a worn out leather non airbag steering wheel with cc switches. I have a good wheel from a 97 F150 with air bag and cc switches that I want to put on it. The old wheel didn’t use a clock spring, the new one does. I have the clock spring for the new wheel. The problem is that both the clock spring and F150 steering wheel are 90 degrees off. Do I have to change columns and if so will the F150 column interchange? And would I have to change everything all the way down to the steering gear?
Old Oct 24, 2020 | 11:04 PM
Edgethis's Avatar
Edgethis
For 97, the f150 was a new body style. Completely different as far as i know.
You'd probably have better luck with a 94-96 steering wheel. Should be a straight swap.
Old Oct 25, 2020 | 08:53 AM
Gary Simons
Yes, But I purchased a custom reman wheel from Carid. Built by B&I. They both stated it was the correct wheel. Now they won’t refund my money. Plus I had to find another core to send them cause they wouldn’t accept a different one.
Old Oct 25, 2020 | 08:59 AM
Edgethis's Avatar
Edgethis
If you post some pictures we can see if there's a way to make it work. Thats new territory as far as I know. I've read about folks swapping in newer steering wheels, but it was the 04+ model wheel.
Old Oct 25, 2020 | 11:55 AM
Dan P's Avatar
Dan P
If the item was not as described, and you tried to work it out and they refuse, dispute the charge with your credit card company. They will get it worked out....
Old Oct 25, 2020 | 02:56 PM
Gary Simons
Ok, I think I have figured it out. Did some research and found that the 96-07 f250 and 350 use a different clock spring than the 150. Just have to find one and try it. Then I jist have to re-key the wheel to the correct orientation.
richlars
Aug 14, 2018 09:06 PM
rdweathers
Feb 6, 2012 09:11 AM
Bernie Lomax
May 28, 2008 08:52 AM
