Help please
Old Oct 24, 2020 | 04:50 PM
Rehamxela's Avatar
Rehamxela
Help please
So the other morning I started my truck for work went back,inside to let it warm up whrn I came back out it was no longer running and has not run since. Since then I have put in New batterys , fuel filter, cam position sensor, and fuel pump. Still not starting and the pump is not pumping fuel. I'm thinking the issue is in the fuel tank. Anybody with experience with this that can point me in the right direction would be great.
Thanks
Alex
Old Oct 24, 2020 | 05:04 PM
seville009's Avatar
seville009
may sound simplistic, but have you checked the fuse for the pump? do you know if the pump was getting power when you put the new one in?
Old Oct 24, 2020 | 05:12 PM
hobohilton's Avatar
hobohilton
I agree with @seville009 . We all tend to "think the worst". Back track or read the owner's manual.... eliminate the smallest of things FIRST. It could just be an electrical connector that needs to be unplugged and then re-plugged. What do you hear when you turn on the ignition switch?
Hobo
Old Oct 24, 2020 | 05:33 PM
Rehamxela's Avatar
Rehamxela
The fuse is good. One of the first things I checked. I hear a humming sound when I turn on ignition. I am gonna get a test light tommorow to make sure pump is getting power although I'm pretty sure it is.
Old Oct 24, 2020 | 10:21 PM
Lance Helmert's Avatar
Lance Helmert
What year? Diesel? It would really help if we knew what we're working on. I'm guessing diesel because of replacing batteries.
Old Oct 25, 2020 | 04:15 AM
Rehamxela's Avatar
Rehamxela
2001 7.3 diesel excursion.
Old Oct 25, 2020 | 04:39 AM
mecdac's Avatar
mecdac
How much fuel in tank?
Less than 1/4 ?
If so, probably the fuel tank pick up foot.
Old Oct 25, 2020 | 08:36 AM
Rehamxela's Avatar
Rehamxela
1\2 tank. It was less than a quarter when issue began and I added 15 gallons to see if that was it.
Old Oct 25, 2020 | 11:19 AM
pirate4x4_camo's Avatar
pirate4x4_camo
if you do not have it get Forscan,
https://forscan.org/download.html
a windows 7 computer like this
https://www.ebay.com/itm/Dell-Latitu...Cclp%3A2334524
OBD link sx
Amazon Amazon
then follow this procedure
https://cdn.oregonfuelinjection.com/...diagnostic.pdf
for under $200 bucks you can have almost dealer level PCM access and trouble shoot your 7.3
the other thing you will need is a fuel pressure gauge. check riff raff or Diesel O rings for the adapter into you fuel bowl.
with the above setup and following Oregon diesels flow chart you will diagnose any 7.3 issue.
Brad_81Ford
Jan 15, 2012 10:21 AM
clwoodall_76
Dec 4, 2009 10:11 AM
vaultster
Mar 19, 2007 07:19 PM
jetski310
Nov 18, 2003 06:40 AM
