Speedometer cable
Old Oct 24, 2020 | 03:32 PM
wyroper61's Avatar
wyroper61
Speedometer cable
Any ideas where I can find a new replacement speedometer cable for my 1968 Ford 4x4 manual transmission all i am able to find is 83 inch cable i need at least 118 inchs screw on ends thanks for any help.
Old Oct 25, 2020 | 09:00 PM
donjamer's Avatar
donjamer
Moved to appropriate forum
Old Oct 26, 2020 | 03:46 PM
cstoyer's Avatar
cstoyer
Dana Spicer 24 or NP205?
NVU, Dakota Digital and Classic Instruments make adapters for mechanical cables. I am using the adapter for a Tremec to a mechanical cable from my NP 205 to factory cluster in my 68 4x4. Dakota Digital made the adapter ATP has 120" cable with the correct threaded ends. As far as the adapter for a 24, I'm not sure but I can look at the speedo cable I removed from my 24 and see if the adapter would work. But if I recall the gear end on my cable is different than the 205 set up.
CStoyer
Old Oct 26, 2020 | 07:25 PM
wyroper61's Avatar
wyroper61
Cable
Thank you I will check it out.
Old Oct 26, 2020 | 10:07 PM
stpackard's Avatar
stpackard
This is the one in the correct length if you have a dana24. It plugs into my divorced dana24 and into the stock dash speedometer. I pulled the cable out and put cable graphite lube but I get slight need hop. https://www.ebay.com/itm/281126962673
Old Oct 26, 2020 | 10:49 PM
wyroper61's Avatar
wyroper61
Cable
I did that with the current speedometer cable just looking to install a new one. Found a place to buy a new one thanks
SteveBricks
Nov 30, 2007 01:26 PM
sierraben
21
Apr 17, 2006 05:37 PM
sierraben
Mar 29, 2005 05:53 PM
cjben
Feb 22, 2005 07:23 PM
cjben
23
Sep 9, 2004 08:32 AM
