Just replace the connector. If its a plate on the wall, get a new one. If its the end of the cable, either replace the cable or just crimp on a new connector. There isn't any kind of grease at all, you just have to replace the faulty parts.
What you need to do is contact your cable company. They can send out a tech to read the power levels at various points to see what is causing it.
First you can try replacing the connectors to see if that helps, but the problem may be outside your house. They sometimes have filters at the pole that could go bad..
I have installed a large amount of cable in my home. I have cable outlets in 7 rooms and a distribution system for RF with amplifiers from two media distribution points in my house to all of the cable outlet locations. Initially I just used the crimp connectors from Radio Shack or the local industrial electronic supply house. Unfortunately connections that were exposed to any type of humidity like in the basement or outside corroded fairly rapidly and resulted in signal loss and interference. I noticed that the cable company used silicone dielectric compound on their outside connections which seemed to last fairly well. I have since rewired my house with quadshield and used silicone dielectric grease on all of the connections. I have noticed no problems with loss of signal for 5+ years now. I will continue to use silicone dielectric compound on my connections. When I strip the cable I dip the end of it in silicone before I insert the connector and crimp it. Then I use silicone on the threads etc also. This has worked very well.
The cable techs have checked out the system and seem to like it!
BTW- Make sure you terminate ALL unused cable taps in your home.
I use the the Ideal Crimp Master, with the No. 30-582 jaws. The tool is a little pricey at just under a hundred bucks. Amphenol makes good connectors, and you can get them thru www.newarkinone.com Locally try a Rexal Electric Supply, Amp/Tyco are good connectors. If the connectors get a lot of flexing its a good idea to use shrink tube over the crimp. Never used dielectric grease on them as we were making computer cable connections, and didn't want anything to wind up where it wasn't supposedto be.
The better splitters are polished in color, not the dull bronze, it doesn't hurt to use thread sealer on the threads of the connector, but thats not the problem mount the splitter somewhere out of the weather is the best bet. Copper oxidizes in water and does inside the splitters, thats where you lose your connection. then when you move it you change the connection. I have 3 sets of crimpers, they are OK, but if you pull on the conector, they'll pull out, I use the screw on connectors then shrink tube the wHole thing.
Another question: Are you using RG-6 or RG-59? You should be using the RG-6 with todays digital connections, The 59 will create the same problems you are experiencing. My $.02
I use the same Radio Shack Hex crimper:
Catalog # 278-238, it is quick and easy.
I also have used the Catalog # 278-242 crimper and those connections have lasted also, you just have to crimp several times and go over the crimp again which is time consuming. It produces a good crimp tho that I have had no problems with.
I use the Catalog # 278-248 cable stripper.
I use RG-6/QS Quad Shield cable. It is more expensive and the connectors are larger.
I use RG-6 with compression (not crimp-on) fittings. Zero signal problems in over a year. You might check with your cable company. Mine told me that any time I needed more lengths of cable, they have plenty of them in their shop for free with the ends already on.
Another thing is to only split once. If you have 3 TVs and a computer, put a 4-way splitter/amp on the cable that comes in the house and run from there to each appliance. Don't split the signal in two, then split the already split signal twice to get four runs. Also, don't compress the coax jacket anywhere you secure it to something.
