Suspension
Old Oct 24, 2020 | 12:40 PM
Scott Estes's Avatar
Scott Estes
Suspension
Wanted to get some opinions on a good setup to upgrade the suspension on an 04 X. I know it's been done to death here so feel free to direct me to the thread.
Primarily on road use with some wheeling, but nothing competitive. My front springs are sagging and it's time to upgrade. Everything equal, what us everyone's opinion on the smoothest ride?
Old Oct 24, 2020 | 01:27 PM
SmackDaddy's Avatar
SmackDaddy
Go to the top of this page and click Tech Folder then scroll down to Suspension.
Old Oct 24, 2020 | 01:49 PM
Scott Estes
Bunch of good info on there. How about opinions?
Old Oct 24, 2020 | 02:46 PM
ArmyLifer's Avatar
ArmyLifer
I went with ATS V and C code springs. They give about a 2" lift, but I did them mainly to help level the Ex for towing. For that they are great. If I let air out of my tires down to 60 rear and 55 front the ride is pretty smooth. I tow at 80 rear and 70 front and the ride is not terribly smooth.
Old Oct 24, 2020 | 08:40 PM
Scott Estes
I've only heard good things about ATS
Old Oct 25, 2020 | 11:43 AM
pirate4x4_camo's Avatar
pirate4x4_camo
what does "every thing equal" mean ?
my experience says almost nothing is equal, each thing being unique.
as for "smoothest ride" a suspension tuned to 1.0 to 1.5 Hertz is going to be the smoothest but given the unsprung weight of the Ex axles, tires, springs, drivelines you are always going
to be battling a high unsprung to sprung weight ratio resulting is a less then smooth ride. aka "rides like a truck"
the keys to making the excursion ride quality the very best it can be is.
keep the center of gravity as low as possible
keep the tire size/weight as low as possible
us the least amount of spring rate as possible
spend the majority of your budget on custom tuned shocks.
oh and that isn"t really an opinion per se but a widely acknowledged fact amongst suspension engineers.
Old Oct 25, 2020 | 07:10 PM
Scott Estes
Thanks pirate
the "everything equal" referred to same tire, wheel, steering etc. what suspension setup would be smoothest on road, and still handle some bumpy trails
Old Oct 25, 2020 | 11:35 PM
pirate4x4_camo
Thanks pirate
need more info.
1. what size tire ?
2. What engine ?
3. preferred ride height ?
4. your budget ?
5. How big are the bump ?
6. how fast fo you want to hit those bumps?
7. How long is the bumpy road or more specifically how long will you be aggressively driving on said bumpy road?
answer me that And i can spec you a suspension to achieve it.
Old Oct 25, 2020 | 11:58 PM
Scott Estes
1. 35s
2. 6.0
3. 2-3in > stock
4. cheap and cheerful under 2k
5. Shin high
6. Till the wife hits the imaginary brake on her side
7. May never stop
Old Oct 26, 2020 | 01:53 AM
pirate4x4_camo
1. 35s
2. 6.0
3. 2-3in > stock
5. Shin high
7. May never stop
To achieve #4 you will need #6 to occur at about 5mph unless you increase #4 to about $20+k
shin high is not a bump its a whoop and hitting whoops in an excursion is ungodly expensive.
this is a 36” travel $35,000 front suspension on a pre-excursion aka a centurion. She is gonna need more then a imaginary brake to slow this to under 70mph is your shin high whoops.
your $2k is going to get you a sweet dirt road mobber but not a whoop killer.
sounds to me like a 22210/22415 with bilsten 5100 is your huckleberry
Old Oct 27, 2020 | 12:05 AM
Scott Estes
That is awesome! A different time, in a different life, with a different bank account I would have a whoop killer like that. Thanks for the good info
Old Oct 27, 2020 | 12:44 PM
pirate4x4_camo
OPM bro, OPM
anyhow, like I said, the 22210/22415 with 5100 Bilsteins is hard to beat at $2K and I have little doubt would make ya grin on most any desert road.
Old Oct 27, 2020 | 06:55 PM
Lance Helmert's Avatar
Lance Helmert
I've only played in the yard with it, but I'm excited to take it off road. We've got less than 1000 miles on it, but my wife and I love how it rides and handles.
Old Oct 28, 2020 | 08:30 AM
Squirrel13's Avatar
Squirrel13
Id say the smoothest ride would be achieved by converting front to D60 coil spring from a newer truck. Bigger brakes, better turning and ride. I will do that someday. In the mean time I went same route as Armylifer. V/C springs, Bilstein shocks, rear bags, 285/75/17. I gained 2.25” with springs another inch with tires. After a few trips I learned the X has to be aired down.
Old Oct 28, 2020 | 09:19 AM
Scott Estes
Huge shoutout to OPM
will trade medical advice/procedures for 4x4 parts
there is a plethora of pro comp vendors. Who is worth their salt?
