Injectors Keep Leaking
Old Nov 5, 2020 | 08:45 PM
Charmalu's Avatar
Charmalu
Originally Posted by stevep3916
What kind of clamps are you using?
If you are asking me on the clamps. Iam just using the springy green clamps
that come with the new caps.
Charlie
Old Nov 9, 2020 | 11:14 AM
jjqllc's Avatar
jjqllc
Unscrew one of the hard lines from the top of one of the leaking injectors. Look at the mating surface where the hard line meets the injector. If there is a step in the hard line, that's your leak. If you have been gorilla tightening the lines, you'll eventually recess the steel and if you don't get it perfectly down, it will leak. I had it happen to me, so I know. You'll have to pull the bad hard line, and either file or dremel the end back into the same original shape. Some lines you might not be able to get to on the pump, so if you do find a couple recessed lines, you might want to pull the pump and do them all. Make sure you clean them out good.
Old Nov 9, 2020 | 11:26 AM
DarkOverCast's Avatar
DarkOverCast
You can get the lower lines off with the pump on, however you have to remove the upper lines to make room. You'll need a line wrench.
Old Nov 9, 2020 | 11:35 AM
jjqllc's Avatar
jjqllc
Line wrench? They make a specific tool for these? Guess pulling the lines would work too, bottom ones would suck.
Old Nov 9, 2020 | 11:53 AM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
yeah, specific way to install and remove lines.
Old Nov 9, 2020 | 11:59 AM
jjqllc's Avatar
jjqllc
This one is a keeper. Thanks
Im50fast
Oct 21, 2018 08:48 AM
DesertZuki
Dec 21, 2015 10:59 PM
ArlyDude
52
Sep 1, 2013 08:12 PM
IDIDieselJohn
Jul 6, 2009 10:12 PM
stevegold1958
Apr 14, 2007 07:49 PM
