Need Help Identifying OXYGEN SENSOR Numbers's:
Old Oct 22, 2020 | 03:45 PM
unilover6163's Avatar
unilover6163
Hello friends,
I am getting conflicting information from my Ford Dealer on Oxygen Sensor (O2-sensor) Part Numbers for my truck???
My truck:
- 1990 F350 Cab/Chassis 4X4, 460 (7.5L) gas, ZF 5-speed, Dana 60 front, Sterling 10.25 rear, 4.10 gearing.
- Calibration Code: 0-97A-R05 as seen from decal #: F0AE-6E061-EEF
- VIN#: 2FDKF38G5LCA71178
- Original Front Exhaust Crossover Pipe still in place (Part #: E9TA-5246 JA or Part #: E91A-3246-JA) but it is stilghtly rusted over to distort the Part Number, but has the crossover 'bung' for the O2-sensor between the pipes.
- The Factory Original Plug-In Connector for the Oxygen Sensor is a 4-wire female connector on the truck-side of the harness, HOWEVER, the actual Oxygen Sensor that is currently installed into the 4-wire connector in my truck is a 3-wire O2-Sensor with the following numbers on it: "E97F-9F472-DA" as well as "950241"....
When I spoke with the Ford Dealer today they mentioned the following 3 Oxygen Sensors for me to research and consider, but I'm not sure if they are 3-wire, or, 4-wire Oxygen Sensors???:
1. Ford Part #: E7TF-9F472-A (Motorcraft #: DY604)
2. Ford Part #: F07F-9F472-A (Motorcraft #: DY586)
3. Ford Part #: F0TZ-9F472-C (Motorcraft #: DY586)
My questions are as follows:
A. Since the truck harness has a 4-wire connector with all four wires having a metal 'Pin' inside the harness connector in 'like-new condition' can I assume that a 4-wire Oxygen Sensor should be installed into that connector instead of the currently installed 3-wire O2-sensor (E97F-9F472-DA & 950241) that is there at this time?
B. If I should require a 4-wire O2-Sensor, then what is the Ford Part Number and/or the Motorcraft Part Number, based on the calibration Code on my truck listed above?
C. If my truck actually does use a 3-wire O2-Sensor, then are one of the three sensors listed above the correct O2-sensor for my application, OR, is the O2-sensor currently installed the correct O2-sensor for my truck???
Many thanks in advance for everyone who might chime in with some information -- Pete
Old Nov 27, 2020 | 07:20 PM
unilover6163
Can anyone offer any information on Ford OEM Oxygen Sensor (3-wire and/or 4-wire)?
Again, I have a 4-wire connector on the truck-side of the harness.
Still haven't got any definitive information as to whether Ford put a 3-wire or 4-wire Oxygen Sensor in my truck from the factory???
Anyone out there have any information? Part Numbers? etc...
Many thanks in advance, Pete
Old Nov 27, 2020 | 08:06 PM
torq'ta 5 8's Avatar
torq'ta 5 8
If you dont have any O2 sensor codes, I would put the 3 wire back in it, which 3 wire, will depend where your O2 plug is, or measure yours, there was a crossover year, when Ford went to 4 wire, and it seems 90-91 was the area.
Golflug
2015 - 2020 F150
Dec 28, 2016 08:09 PM
Snuggyworm
Jan 6, 2014 09:31 AM
Zixxer
Mar 6, 2013 09:02 AM
JOE SKI
1997 - 2003 F150
Nov 4, 2008 12:21 PM
kiteman
Sep 23, 2003 07:48 PM
