4x4 Woes
I've had this truck for 5 years and my 4x4 operation has never been reliable. First the transfer case had issues so I rebuilt that. Then the linkage was broken so I fabricated one that works. I've replaced all ujoints and rebuilt my driveshafts. Front hubs are new Warns that click into place like they should.
I was confident that all of this would get my 4x4 working but tonight was the first time I had to test it and it failed miserably. Was stuck in the mud, shifted the transfer case into 4L, locked the hubs and..... Nothing. Still stuck.
Got it winched out and into the shop. Confirmed that the front driveshaft was engaged. Put the front up on jackstands and the hubs seem to lock.
With hubs unlocked: both wheels spin freely from the driveshaft.
With hubs locked: both wheels spin opposite from each other when spun by hand.
Put the rear up on jackstands and with tc engaged and the truck in gear, rear wheels both spin in the same direction. Passenger front spins in forward direction. Driver front doesn't spin at all.
What the hell is going on??
If one front wheel spins with power and the other doesn't , assuming they're both off the ground, it sounds like your driver front hub isn't engaging properly. just because it moves the other wheel by hand doesn't mean much it takes very little to do that.
Or, if there are two of you, you can turn one while the helper holds the other one steady. If the spinning one becomes notably harder to turn, chances are you have a limited-slip diff.
For checking the locking hubs, yours should be an open-knuckle diff with the axle u-joints visible. Correct?
If so, then you can lock a hub and try to spin the wheel while you jam a prybar or similar locking device into the u-joint area. If you can't turn the wheel in either direction with the axle locked up like that, the lockout would seem to be working. But definitely try to spin it in both directions, just in case.
Seems like that would be a relatively definitive test.
By the way.. Are you sure that this is a part-time NP205 transfer case, and not a full-time NP203 that was converted?
And speaking of unknowns (to us at least) just how did you modify/fix the shift linkage on the t-case? Are you sure that both shift rods are going into their proper detent positions when expected? It does sound as if they are, but I figured I'd check since I'm curious about the linkage.
The reason it seems to be working at the t-case is that you said that when shifted into 4WD the front shaft is engaged. Meaning you can't turn it by hand while in 4WD. Correct? If so then it seems that the t-case is working fine (thanks to your fixing it before) but something is going on up front.
Obviously not sure here either. Just spitballing for the moment until some sort of Ford light bulb moment happens with someone!
Good luck.
Paul
Good luck.
Paul
I'm not sure exactly what my front axles look like but will try to check them out tomorrow.
The reason I don't believe I have a locker in the back is whenever I get stuck in snow or mud I only have a one-wheel-wonder under me. My bmw has a limited slip rear end and never gets stuck. How embarrassing is it that my huge truck on 37s is a disaster in the snow!?
We used to see this all the time in the factory Ford limited-slip diffs. Customers would complain about the units not working right when they got about to the 60k mile mark or so. Seemed like a consistent mileage to where they became ineffective.
Guess we won't know until you get the time to open it up and take a look-see. Maybe your open diff just happens to have enough internal friction that the unloaded wheels will spin the same direction even where no limited-slip is present.
Don't know if it's possible, but I can see that happening in my mind.
Paul
And stop that leak at the same time. Is it coming from the cover gasket (hopefully)? Dana 60 I presume?
Paul
I think I have found the issue (maybe.) Both hubs seem to lock and if I get it into 4L I think it works..... But the problem is actually getting it to shift into 4L.
I can shift from 4H to 2H to N with my shifter without any issue.... And sometimes it seems like it goes into 2L. But getting into 4L is absolutely impossible without crawling under the truck and wiggling the front drive shaft while someone else works the lever. I've put a big pipe over the shifter and everything is solid, I just can't get it to engage without some help. Obviously when you're stuck you are in the mud or snow or on the boat ramp so this is less than an ideal place to be crawling around.
Any tips/ideas on how I can improve/fix this?
But yours is the base model at least in the rear. Since front and rear could be optioned separately with limited-slips (I believe) you can still have a different setup in the front.
Have you changed the gear lube in the transfer case lately? Maybe cleaned up the exposed part of the shift-shafts and lubricated the pivot points on the shift mechanism?
Hard to imagine that just a little lube can fix something that can't even shift with added leverage, but you never know. And it never hurts to optimize as much as possible to narrow down the issue. Could be one thing, could be a case of "stacked tolerances" fighting you.
Good luck. Sorry not more insight into the shifting thing.
Paul
This was my first time doing a rear diff change..... People aren't kidding about the smell. My whole shop stinks now!!
