Modular V10 (6.8l)
Code Help P0113 and P0102
Old Oct 21, 2020 | 05:43 PM
COsby's Avatar
COsby
Hey all,
Well long story short the truck is just coming back together from the heads coming off and exhaust front to back.
The engine feels very nice but it's running rough, like the feeling of a coil pack out.
I have codes P0113 and P0102.
Also, when I shut the truck off you can hear a puff from some hose around around the intake. It's the big hose that comes around from the back of the intake with the big bulb in the middle. Thinking about it though it might have always .are that noise with the k&n tube.
The truck does have a K&N intake tube and filter. That has been on there for a very long time.
I thought it was one of the intake tubes crossed but best I can tell those are hooked up right.
Any help is greatly appreciated
Old Oct 21, 2020 | 07:31 PM
COsby's Avatar
COsby
It looks like I'm going to start by cleaning the maf and ensure there aren't any cracks.
Old Oct 23, 2020 | 10:00 AM
COsby's Avatar
COsby
Alright, step 1, make sure everything is connected properly...
For whatever reason when I took my intake piping off I disconnected the maf at the harness to body main and not the harness to the maf itself.
However, I still have a miss but I know roughly where it's coming from. Also no codes, so I have a good idea what it is. Unfortunately by the time i get home tonight it's supposed to be storming.
That said, if you do have this code and need to go further,
Check your maf for cleanliness and for any damage.
Also, it's a very sensitive sensor. Brake cleaner or throttle body cleaner can damage the element.
Old Oct 24, 2020 | 05:35 AM
JWA's Avatar
JWA
The chemical solution of TB cleaner would be more highly recommended than brake cleaner. Even so its not so much the chemicals as it is how close the stream from an aerosol can is to the MAF elements that cause issues. They're so very fine damage can happen quite easily.
brachear174
1997 - 2003 F150
Oct 29, 2012 05:40 PM
cHiLi 11
6.4L Power Stroke Diesel
95
Apr 18, 2010 05:03 PM
Firemudder
Apr 16, 2010 07:01 AM
Lduncan7
Dec 8, 2009 03:56 PM
pullinair
19
Oct 5, 2008 09:56 PM
