Stock electric choke
Old Oct 19, 2020 | 10:05 AM
Ryanalofs's Avatar
Ryanalofs
Hey all. My '79 f150 has a stock 2150 carb with an electric choke. When I put my voltmeter + on the wire to the choke and the - the the ground, it only reads 2.1 volts. Can someone direct me where to look for bad connections?
Old Oct 19, 2020 | 10:09 AM
ford390gashog's Avatar
ford390gashog
Did you check with the truck running? The stock choke runs off the stator wire on the alternator.
Old Oct 19, 2020 | 02:18 PM
meangreen92's Avatar
meangreen92
And that wire to the choke is AC current, not DC like the rest of the truck. Alternator has to be spinning and energized.
Old Oct 23, 2020 | 05:06 PM
NoHecks's Avatar
NoHecks
I just picked up a 74 302 f100 for a couple grand. Needless to say the wires are in disarray. Nothing plugged into the choke. You said the stator wire from the alternator goes to it? Have two wiring diagrams but neither has the choke in the schematic.
Old Oct 23, 2020 | 11:08 PM
meangreen92
I didn't say because I can never remember which alternator terminal it is, but that sounds right.
Check the schematic which shows the pin-out from the alternator - that might have it. If not it should be pretty easy to find online.
Old Oct 23, 2020 | 11:20 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
From what I understand, this is the elec choke power plug?
Jerry_85ford
Mar 20, 2020 07:51 PM
79lownlong
Dec 6, 2014 05:28 PM
78ford351m
Dec 3, 2008 01:35 PM
E30tdf
Nov 13, 2007 07:48 PM
78RangerXLT
Feb 24, 2003 10:07 PM
