Dropping 6.0 back in
Old Oct 17, 2020 | 10:20 AM
devils toy's Avatar
devils toy
For those who yank there motors and put it back in. Is it easier to bolt up to the tyranny or install the motor mounts? I'm doing it myself. No easy task.
Old Oct 17, 2020 | 08:47 PM
LindenBruce's Avatar
LindenBruce
Do you mean before or after? With the tight fit on your application, I would get the tranny connection first then raise the engine up and slip in the mounts. Sound right? B.
Old Oct 18, 2020 | 12:25 PM
SmackDaddy's Avatar
SmackDaddy
It’s possible to install with engine mounts on the block and still stab torque converter bolts to the flywheel.
Old Oct 18, 2020 | 02:35 PM
Corlyn Brown's Avatar
Corlyn Brown
I haven't put mine in yet but but I bought a 3 foot long piece of threaded stock (cut into 4 pieces) to aid me in aligning things up. I'll thread pieces into engine and use them to line up then tranny! I also lifted the body and stuck 2x4s where the mounts are. 6 bolts under carpet and and 2 in the engine bay by the bumper. Just pull back seat and lift carpet. Easy peasy to get too. I left the 2 most rear ones in place and just lossened them 3/4 of thread so cab couldn't move one side or the other jacking up and lowering it back down.
Old Oct 19, 2020 | 08:04 AM
MisterCMK's Avatar
MisterCMK
I left the mounts on the engine block when I reinstalled my engine but I did have help.
We dropped the engine into the cradle and the tranny lined up at the same time. We did loosen the trans mount bolts and i did have a tranny jack under there as well.
Old Oct 19, 2020 | 08:40 AM
SmackDaddy's Avatar
SmackDaddy
Yessir! I blocked my transmission in place before removing the engine and stabbed it the same way without having to move much to get TC studs to line up with the flywheel. The engine mount studs cleared the crossmember by about 1/4-1/2” so it was tight but doable.
Old Oct 19, 2020 | 03:36 PM
MisterCMK's Avatar
MisterCMK
That reminds me, set the studs so one is at the bottom on the converter and then set the flex plate so one of the holes lines up BEFORE you put the engine in. I may have had to pull mine back out and line them back up. LOL
Old Oct 19, 2020 | 03:45 PM
SmackDaddy's Avatar
SmackDaddy
No need for all that. Roll the crank with a breaker bar and socket on one of the harmonic balancer bolts. Shine a light from the front and use your 48” extension to get the nuts on.
Old Oct 19, 2020 | 09:32 PM
MisterCMK's Avatar
MisterCMK
We just couldn't get it to line up right. Must not have had the converter seated all the way into the pump because the studs were hitting on the flex plate. Pulled it back out, aligned it and all was good.
Indslpwr04
2009 - 2014 F150
19
Mar 20, 2015 10:45 AM
JaySVX
Oct 17, 2013 01:48 AM
robertbruce
Feb 10, 2013 08:41 AM
Terpfords
Engine Swaps
Jun 7, 2009 09:41 PM
BrianFX4
2004 - 2008 F150
15
Dec 2, 2007 08:40 PM
