Is this simply a "flasherstat" I found under the dash of my '78 F250? Or is it something else?
It was not hooked up to anything. If you can't read it below the 'FORD' emblem it says: D8SB
15B683-AA
7L07
Thank you dlburch, 440 six pack, & number dummy! As long as my blower works I think I can dispense with it, as PO most likely did as well, which is why I found it disconnected from anything under the dash!
Without you guys experience, expertise, & generous sharing I would be UPSHCWP most likely!
