C6 transmission linkage help needed
I have a 64 F100 i am putting a 429CJ motor, have a 73 C6 out of a Lincoln behind it.
I have a Steering column from a 79 f250 i am putting in. I was told the linkage bracket coming out of the trans was specific to linkage.
Does anyone know if this is true Have any pics so I can see what linkage rods and brackets anything i need to make this setup work?
Thanks
Dave.
Car levers point up. Truck levers point down. You can reverse the lever at the trans but you have to pull the valve body to do so.
You have quite a mix of components. I thing you will need the actual shifter linkage that came from the '79 F250 and the kick-down from the Lincoln.
