Change permanent keypad access code?
Old Oct 14, 2020 | 02:16 PM
shawnee1's Avatar
shawnee1
Of course there is the Ford door handle design that allows a thief to break into your truck with nothing more than a pair of pliers and about 10 seconds. A good thief will leave no marks to indicate the truck has been entered.
Old Oct 14, 2020 | 02:56 PM
Ding126's Avatar
Ding126
When you sell the truck, you dont always give up pass codes. So ford can now reset back to factory for the new owner. IMO, its no different than your key code, A key can be cut with the code as well. Windows can be broken to access the vehicle. tow truck can hook up and take your truck. If there is a will there is a way...
Dont sweat or over think it. I doubt you will find a case that some out outside your circle has entered your vehicle with the factory door code...other wise it would be all over the net
Old Oct 14, 2020 | 03:27 PM
maypo59's Avatar
maypo59
was going to say the exact same thing.. with a little practice a bad guy can be in faster with a pair of channel locks then you can type in the code..
SMMoore
Jan 10, 2020 05:21 AM
kaufmansm
Apr 1, 2014 08:11 PM
THaywood
Sep 12, 2012 06:16 AM
LUCYLITTLE
18
Aug 15, 2005 10:16 AM
hancockr
Jul 23, 2003 06:10 AM
