Bad Window Regulator?
Old Oct 12, 2020 | 04:55 PM
woodsmoke's Avatar
woodsmoke
I bought new window regulators years ago from one of the big after market suppliers. They have not been used a lot. They always had a clunk clunk clunk when rolling up. About every 1/4 turn . Now drivers side ,because it is used more, is apparently stripped out. I can help window up by pulling on it. That's it. I don't know if there were bad regulators going around back then or what. Any recommendations where I can get a good quality regulator is appreciated. Or. Is just a roll of the dice? My 1966 F100 with original regulators work like silk. Thanks.
Old Oct 13, 2020 | 06:40 PM
leonharu's Avatar
leonharu
That would be Regulator Roy.
https://regulatorroy.net/
Old Oct 13, 2020 | 10:09 PM
woodsmoke's Avatar
woodsmoke
Thanks,leonharu. At least I got one response.
Old Oct 14, 2020 | 06:55 AM
leonharu's Avatar
leonharu
I forgot to mention I think Roy mainly deals with nice NOS regulators.Passenger side are a lot easier to find than drivers side,of coarse that would be normal!
Old Oct 14, 2020 | 07:15 AM
robertrpeak's Avatar
robertrpeak
Just curious, have you inspected the part? There has to be a reason for the clunk, are there teeth missing from the gears? Is the handle slipping on the shaft? Not really much else that can go wrong.
Old Oct 14, 2020 | 08:31 AM
Bret (OH)'s Avatar
Bret (OH)
I have never understood why aftermarket stuff cannot be reproduced with the exact same quality as OEM, but it usually is not. I had to use a repro regulator in the drivers side of the 53, and the quality comparison to the original is stark. The repro is much more springy and less ridged in its construction. It works better than the worn out original, but I bet it wont work as long.
Old Oct 14, 2020 | 09:46 AM
avf100's Avatar
avf100
The new repros I purchased clunk also...almost as bad as the original ones
Old Oct 14, 2020 | 08:16 PM
woodsmoke's Avatar
woodsmoke
Thank you everyone for info. I have not pulled regulator yet. I do know that handle is not spinning on the regulator shaft. Would like to get a replacement first. Do not like to name drop. But. I got these from Mid Fifties Ford. Always had good luck with them. I would guess all those places get their parts from the same places.
Old Oct 15, 2020 | 05:54 AM
leonharu's Avatar
leonharu
Woodsmoke there are several on ebay now that are used.This one appears to at least to look good.Not for sure if it is the side you need.
https://www.ebay.com/itm/1953-1954-1...kAAOSwI3RW~Hl8
Old Oct 15, 2020 | 06:32 AM
bigwin56f100's Avatar
bigwin56f100
. I have used 53-55 on eBay right now for less than the linked one previously posted. It’s been out there for months
SpankF100
Jan 6, 2005 10:12 PM
67f100
Oct 20, 2003 08:21 PM
caseyatthebat1
Feb 11, 2002 05:01 PM
