driver side window(and passneger)
Old Oct 20, 2003 | 09:08 AM
67f100's Avatar
67f100
Question driver side window(and passneger)
I have a 67 f100. I need to replace a driver side window. I do have the little wing windows. I was wondering if the 67-72 windows all would work or did they change them at some point. My other question is the passenger window when your driving it just kind of works its way down by itself, like it's being rolled down real slow.(sounds scary, dont it!) What would be the problem there? Any help would be appreciated! Thanks.
Old Oct 20, 2003 | 02:49 PM
DesertFE's Avatar
DesertFE
67f100,
I believe the windows are all the same. My 70 is the same as my 72.
Two things I can think of on the self lowering window: Bad window regulator and bad window weather-strip not giving any friction to the window. I replaced my weather-strip on '72 pick-up and boy does it stay up now. Of course it so tight now that I broke off the window crank ****.
Old Oct 20, 2003 | 04:38 PM
rebocardo's Avatar
rebocardo
Usually the little gear inside the regulator is worn down.
Old Oct 20, 2003 | 05:56 PM
Opiewan's Avatar
Opiewan
i have the oppoiste problem, mine are a pain to get down, i even greased the rail inside and they are still a apine to get down, but they go up real nice ???
Old Oct 20, 2003 | 06:09 PM
mk's Avatar
mk
Just a note here if you have to change regulators: 67-72 will all interchange.
mike
Old Oct 20, 2003 | 08:21 PM
MudinMan19704x4's Avatar
MudinMan19704x4
Windows are also all the same.....
