High Idle
Old Oct 10, 2020 | 08:05 PM
Jim L.'s Avatar
Jim L.
High Idle
Hello all
My 89 F-150 had been experiencing a high idle. 1100-1300 rpm. I replaced the stock throttle body with a new BBK unit. It still has the same idle characteristics. The truck is a two wheel drive with the 5.0 and 5 speed manual transmission. Any help would be greatly appreciated. Thanks Jim
Old Oct 10, 2020 | 08:08 PM
kenny nunez's Avatar
kenny nunez
High idle
The gasket below the plenum is known to be the source of what you are describing.
Old Oct 10, 2020 | 08:58 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Before you replaced the throttle body did you unplug the IAC? If so, did the truck barely idle or stall? If not you have a vacuum leak which you still have.
Old Oct 11, 2020 | 05:20 AM
torq'ta 5 8's Avatar
torq'ta 5 8
did you follow the instructions after installing
BBK-3503.pdf
Old Oct 11, 2020 | 06:25 AM
My4Fordtrucks
BBK-3503.pdf
Forgot that you need to adjust the throttle stop screw on the BBK to set idle speed and TPS voltage when first installed.
sandymane
322
Mar 24, 2017 07:36 PM
enzer2406
Feb 18, 2011 01:39 PM
kjg26
Feb 5, 2006 01:05 PM
shenderson141
Mar 28, 2002 09:39 PM
