bad idle ,
Old Mar 27, 2002 | 04:18 PM
shenderson141's Avatar
shenderson141
Post bad idle ,
94 302 f150 atuo 4x4, after I start it and it comes down off of the high idle warm up, its idle goes high then low almost dies then repeats this, Ive wiggled all the wires ,sprayed throttle body cleaner in every hole, but still no luck is there a sensor or some such thing I could try to do myself thanks.:-steve
Old Mar 27, 2002 | 05:38 PM
Wilber15's Avatar
Wilber15
bad idle ,
I had this same problem. They say to take the throttle body off and spray and wipe it out. then take the idle bypass sensor off and and clean it. I also bumped my idle up slighlty with the idle screw on top of the throttle body. My idle was a little low, and when i bumped it up to about 900, it dramatically reduced the fluxuation. now it stays between 500 and 900. I still have to take the throttle body off and clean it though. Might do it this weekend over easter break from school. laterz.
Old Mar 28, 2002 | 08:59 PM
Lightning2Fast's Avatar
Lightning2Fast
bad idle ,
definitely do what wilbur said. if it doesnt work then start huntin for the vacuum leak. upper intake gasket maybe?
Old Mar 28, 2002 | 09:39 PM
dewey_gubbels's Avatar
dewey_gubbels
bad idle ,
