Measurement needed
Old Oct 22, 2003 | 07:37 AM
jcs1966's Avatar
jcs1966
Measurement needed
The guy who had my truck before me added a spacer between the intake and the carb and cut and welded the bracket that holds the throttle cable and made it longer. I put on the original carb without the spacer and now of course the bracket is too high. I need the measurement from the "flat" part or the bracket to the center of the hole that the bolt screws in to. Also the throttle cable is like broke in the middle of the two metal covers. Why was there a metal end to hook to the carb and then plastic tubing and then another metal covering????
Old Oct 22, 2003 | 10:51 AM
William's Avatar
William
I think you should retain the spacer. Either use a plastic or wood spacet or if you can find one the water heated/cooled type. LoKar makes a nice cable and bracket. After that its time for a trip to the Junk Yard.
Old Oct 22, 2003 | 03:05 PM
Rosati's Avatar
Rosati
What size engine and type of carb? My 64 uses a rod and linkage to the pedal. Your truck must be a 65-66?
Old Oct 22, 2003 | 03:08 PM
jcs1966's Avatar
jcs1966
Sorry!!! Yes 1966 with 352 with a (now) stock carb
KsCop
Feb 21, 2021 02:19 PM
bob_351
Feb 21, 2021 01:03 PM
PharmerChris
45
Jan 11, 2020 01:08 PM
perks56
Dec 17, 2013 08:11 AM
fordboy300
Jan 31, 2012 12:52 PM
