Fluid when removing axle shaft
Old Oct 5, 2020 | 06:58 PM
Jayv10's Avatar
Jayv10
So I’m doing my ball joints (the old ones move like an Atari joystick). I removed the axle shaft and I got a good flow of differential fluid. This isnt normal right?
Old Oct 5, 2020 | 08:38 PM
Dweber85rc's Avatar
Dweber85rc
It is from the differential. This isn't abnormal if you pulled the shafts out. If you put them back in and it still leaks then your inner seals are shot.
Old Oct 5, 2020 | 08:56 PM
lexustech48's Avatar
lexustech48
Also, if you have the front axle up on both sides, a slight lean of your work surface may cause fluid to flow out as well. As long as it wasnt alot, you should be ok. Same thing happened to me a few weekends ago.
Old Oct 6, 2020 | 10:10 AM
Jayv10's Avatar
Jayv10
It was a bit more than a little. Ugh. Guess I’m replacing that seal as well. As long as I don’t engage 4wd I should be ok to drive it down to get fluid and everything right?
Old Oct 6, 2020 | 11:40 AM
Dweber85rc's Avatar
Dweber85rc
Do you know when the last time the fluid was changed and if so how much was put in? If it was overfilled that would certainly cause a lot of fluid to come out and not really mean your seals are bad
Old Oct 6, 2020 | 01:48 PM
jasonodsky's Avatar
jasonodsky
Don't assume the inner seals are bad. It's normal for some fluid to flow out when you pull the axle. @lexustech48 has it right, explaining the angles that can cause fluid to flow out. If you didn't have an obvious leak out the end of the axle shaft before you pulled them, then those seals may be just fine. It's possible the re-install may damage them but I've pulled axles and reinstalled and the seals were just fine.
I finally had one go bad (slow leak for the past 5+ years suddenly started leaking a lot). I used the Torque King inner axle seal installer ($180) but it was worth it. It went very easily using the install tool.
If you decide to do the inner seals, PM me and we can work out a borrow/loan plan for the install tool.
Hang in there,
Jasonodsky
Old Oct 6, 2020 | 07:25 PM
Jayv10's Avatar
Jayv10
Thanks for all the info guys. I’ll let you know when I get it all worked out. Appreciate it.
captain p4
Offroad & 4x4
16
Mar 23, 2013 12:18 PM
John Rowe
Nov 28, 2012 02:42 PM
sillyjt
Aug 7, 2012 11:39 AM
Bennyboy2002
Jun 15, 2010 07:51 PM
Ford150/428/dud
Offroad & 4x4
15
Feb 7, 2008 08:04 PM
