Sponsored by: Real Truck
TPMS Interchangeability?
Old Oct 5, 2020 | 12:40 PM
PatrickStapler's Avatar
PatrickStapler
Can anyone tell me if these will work on my truck? 2015 F-250. I purchased a used set of 2019-2020 Ford 20” wheels and the shop gave me four of these. Said they were all scanned and functioning. However, when I look up the part number for TPMS sensors for my truck I get a different part number of 9L3Z-1A189-A. Same frequency, different part number.
What I have: GL3T-1A180-GB
Old Oct 5, 2020 | 04:38 PM
Just Strokin's Avatar
Just Strokin
It appears the GL3T-1A180-GB are off the F-150 truck. If you or the tire shop has the handheld tpms reset tool, you could put your truck in learn mode and try to get it to learn one of these sensors. If it learns the sensor, then you can use them with no problems. If it doesn't learn it, then you probably need to get the ones compatible to the 9L3Z-1A189-A.
Old Oct 6, 2020 | 07:23 AM
92sho16's Avatar
92sho16
The 17+ supder duty's use a different frequency sensor.
Old Oct 6, 2020 | 07:24 AM
PatrickStapler
So your saying these possibly could work in a ‘15? If not, where is the cheapest place to get Ford sensors?
Old Oct 6, 2020 | 07:30 AM
Just Strokin
Go to eBay and buy them. These and the ones used at the local tire store will be cheaper than buying from Ford.
Old Oct 6, 2020 | 07:31 AM
92sho16's Avatar
92sho16
The sensors themselves will NOT work, there are two different frequencies of TPMS 315 and 433. When i had 2019 takeoffs on my truck there was no pairing happening. Be sure to get could quality motorcraft sensor, I bought what i thought were genuine sensor off ebay and they pair fine but dont read right and caused my light to come on all the time.
WaxOnWaxOff
Apr 29, 2020 06:54 PM
DisabledVet262
Apr 28, 2003 12:06 AM
78f250lj
Aug 28, 2002 01:24 AM
