Can anyone tell me if these will work on my truck? 2015 F-250. I purchased a used set of 2019-2020 Ford 20” wheels and the shop gave me four of these. Said they were all scanned and functioning. However, when I look up the part number for TPMS sensors for my truck I get a different part number of 9L3Z-1A189-A. Same frequency, different part number.
It appears the GL3T-1A180-GB are off the F-150 truck. If you or the tire shop has the handheld tpms reset tool, you could put your truck in learn mode and try to get it to learn one of these sensors. If it learns the sensor, then you can use them with no problems. If it doesn't learn it, then you probably need to get the ones compatible to the 9L3Z-1A189-A.
What I have: GL3T-1A180-GB
The 17+ supder duty's use a different frequency sensor.
So your saying these possibly could work in a ‘15? If not, where is the cheapest place to get Ford sensors?
The sensors themselves will NOT work, there are two different frequencies of TPMS 315 and 433. When i had 2019 takeoffs on my truck there was no pairing happening. Be sure to get could quality motorcraft sensor, I bought what i thought were genuine sensor off ebay and they pair fine but dont read right and caused my light to come on all the time.
