Weird noise and feel between 40 to 55 mph
Old 10-04-2020, 08:33 PM
RAIDER NATION12's Avatar
RAIDER NATION12
RAIDER NATION12 is offline
My 07 f150 makes a weird grinding or studder sound while I accelerate lightly and from time to time it will feel like it limps as I accelerate as well anyone have any ideas of what it could be? Thanks
Old 10-04-2020, 08:36 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
Sounds like a typical low-grade misfire. Maybe a torque converter issue.
Old 10-04-2020, 08:38 PM
RAIDER NATION12
Thank you I’ll check into it
Old 10-05-2020, 08:40 PM
redfishtd's Avatar
redfishtd
redfishtd is offline
Its typical misfire especially at that speed . it shifts into high gear and starts lugging which shows up misfire shudders. Many guys have wrongly worked on their transmissions for these misfires . Going up a slight hill will also trigger this .
Bad plugs /bad boots, dirty cop connections ,connectors not locking on . Torque pro $5 dollar app +android phone +cheap amazon bluetooth reader under test results will give you per cyl raw computer counts going towards setting a misfire cel . Its under a mode six report on readers . so clean your cops contacts real well ,put new plugs and boots on . Solder in new connectors not locking on .
You can't really diagnose this engine until the ignition circuit is first class and clean .
jt371
03-23-2009 12:27 PM
Ray_K
09-10-2007 05:34 PM
Skandocious
20
08-01-2007 01:18 PM
gsg1970
04-03-2007 10:16 PM
Spyder369
1997 - 2003 F150
06-22-2003 03:55 AM
Quick Reply: Weird noise and feel between 40 to 55 mph
